Is possible to free memory without reset?
    _ThEcRoW
    Posts: 298 from 2008/10/27
    Hello guys, lately i'm using morphos more than ever, and the thing i noticed hte most, was when using owb for long period of time(like half day) and with many tabs(only 4 or 5) i have seen that the free memory available descend to 400mb even to 200. Closing owb won't release the memory, at least not all, so i was asking if there is some tool that can free the memory like it was used in the classic. I remember i used a program on my 1200 that when executing it, would free the majority of ram in the system. Are there another ways to do it?. Per se it's not an issue because morphos boots fast, but i would like to know if it's possible at least to extend the session time until it is needed to reboot.
    And by the way, kudos to the MorphOS team for the upgrade, as every day it passes i'm more convinced that it was the best "amiga" purchase i ever did.
    Thanks in advance!!!
  • »14.11.15 - 08:28
    Yasu
    Posts: 1724 from 2012/3/22
    Well, you can press F12 in OWB to free up a little memory. That's all I know.
    My MorphOS blog
  • »14.11.15 - 08:54
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    Open a shell window and execute avail flush in it.
    It frees all avail unused libraries and mui classes.
  • »14.11.15 - 09:19
    Posts: 12543 from 2003/5/22
    More info there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11161&forum=3&start=11
  • »14.11.15 - 11:44
    Posts: 2217 from 2003/2/24
    Hmm.. I haven't noticed much wasted memory when quitting and relaunching OWB, but if I happen to get the memory requester, it hits and doesn't free the memory then nowadays. So, I'd make sure you always quit OWB before getting the requester.
  • »14.11.15 - 16:19
    Posts: 1386 from 2010/1/6
    Also very useable: http://aminet.net/search?query=sysflush
  • »15.11.15 - 15:40
    _ThEcRoW
    Thanks a lot for the replies. Will try the avail flush command the next time i'm on my mac mini. I recall that command from the 3.x classic os, isn't it or was an addon byt third parties?.
  • »16.11.15 - 17:50
    avail is a (original) AmigaDOS command.......and now also MOS native....... (MOSSys:c/avail)
  • »16.11.15 - 19:28
    Cego
    Posts: 738 from 2006/5/27
    i would also recommend to upgrade your ram to at least 1.5gb if its possible
  • »16.11.15 - 22:39
    Cool_amigaN
    Posts: 776 from 2011/11/30
    I made the command to be execute from a script, but here's my question: How will I make the script autoexecuted when avail. ram is below 25% and while avoiding the command to full in a loop?
  • »17.11.15 - 15:39
    _ThEcRoW
    Unfortunately, the mac mini doesn't get more than 1gb of main ram. Is there anyone out there who have modded it to get more?. Is possible?
  • »17.11.15 - 18:13
    No.
  • »17.11.15 - 18:51
    Posts: 902 from 2003/3/4
    You don't need avail flush. MorphOS will flush libraries and resources if an allocation comes along it can't fit. AmigaOS selectively freed resources and MorphOS is even more optimised.
    Flushers used to annoy the hell out of me on Amiga. AmigaOS has one of the most simple memory systems out there but people couldn't seem to understand it; they were just fixated on getting that Workbench titlebar to show as high a number as possible. The price of that was constant reallocation so causing memory fragmentation, and a system slowdown because they had to keep reloading all the libraries they kept flushing.
  • »21.11.15 - 21:04
