SSH in MorphOS! Please post
    magnetic
    Posts: 2129 from 2003/3/1
    I have had many people ask me if we have SSH for MorphOS. I hear there is a port or a 68k version of ssh out for us. Does it work? Please post some information.. Thanks
    magnetic
  • »10.01.04 - 17:28
    Doraemon
    Posts: 137 from 2003/7/1
    From beta2 mail list
    The security FIXED version is on my site:
    http://pegasos.innoidea.hu/MorphNIX/bin/internet/openssh-3.7.1p2.tgz
    http://pegasos.innoidea.hu/MorphNIX/bin/internet/openssh-3.7.1p2.readme
    LouiSe
  • »10.01.04 - 19:47
    fprowse
    Posts: 5 from 2003/3/12
    Louise - I've tried your ssh port and it seems to work
    fine with a minimal of install required.
    However (and this isn't your fault) how do you get this
    correctly working with the MorphOS shell so we can use
    terminal apps correctly under unix/linux?
    Francois
  • »28.01.04 - 07:01
    Posts: 154 from 2003/4/22
    Hi !
    For a "true" Linux terminal over SSH you need AmTelnet:
    http://www.vapor.com/amtelnet/
    Unfortunatly it only supports SSH V1 for the moment.
    Bye
    MorphOS Rulez !
  • »28.01.04 - 11:03
    fprowse
    AmTelnet won't do.....most of the machines
    I'm connecting to only support SSH V2.
    Sorry - MorphOS needs to have a decent shell implementation
    and networking tools if you are going to attract the
    geek crowd.
    If an example geek user (non amiga user) was to try
    out a pegasos the first thing they are going to ask
    is "How do I ssh to my linux box?".....They won't like
    the answer.
    FP
  • »28.01.04 - 17:34
  • Targhan
    Posts: 2833 from 2003/2/7
    No, AmTelnet will do, it just needs to be updated :-)
    :idea:Targhan
  • »28.01.04 - 18:07
    porneL
    Posts: 49 from 2003/7/16
    PUTTY is portable and opensource. It works on big-endian machines and gui is separated from the core. Someone wants to port it? :)
    this text is here to confuse you
  • »28.01.04 - 18:52
  • Targhan
    Awesome! I use Putty on my PC, I should have thought of that!
    :idea:Targhan
  • »28.01.04 - 19:35
    fprowse
    Of course AmTelnet needs to be updated but if you look at the last update of this software it is October 2000. If it hasn't been updated in 4 years then there is alot of catch up to play.
    A port of Putty would be a big plus for MorphOS.
    I know I'm demading (but I'm not a coder)
    FP
  • »28.01.04 - 19:43
    SchizMoss
    Posts: 10 from 2004/3/2
    I've got the same problem as fprowse.
    I have extracted OpenSSH in MOS SDK assign gg:
    and I'm able to connect to my Linux server with
    ssh2. I have tried several TERM settings on the
    Linux side but there's always something messing
    up the screen or some keys don't work. I tried
    aterminfo on MOS but it didn't help either.
    Does anyone know how to make it work properly?
  • »10.03.04 - 05:48
    poundsmack
    Posts: 1346 from 2003/6/7
    it would indeed be nice to have putty...i use it for doing work in my comp class at chico state from home...
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »10.03.04 - 05:53
  • Targhan
    /me scribbles a note... Putty...
    Yes, Targhan likes Putty...
    :idea:Targhan
  • »10.03.04 - 06:44
