Open command
  • rms
    rms
    Posts: 606 from 2004/11/27
    I would need to open a window on Ambient in "List" mode and in "All Files" mode using a command like "Open" (is in MorphOS/C). I would also need that this window has a certain size and opens in a certain position on Ambient.
    I can do that when I use Bookmarks where I use the following command:
    PM1-Clients:?view=List&mode=ALL&top=180&left=240&width=540&height=740
    but this seems to work only with Bookmarks :-(
    Does someone know if it is possible to open a window in "List" mode and "All Files" mode using anything else then Bookmarks?
    Thanks for help!
    Regards
    Christoph
  • »09.06.15 - 03:25
    Posts: 847 from 2007/10/23
    Hi!
    You may change the viewmode, see MOSSYS:Ambient/docs/arexx.txt
    Greetings,
    Stefan
  • »09.06.15 - 05:46
    Posts: 1098 from 2004/9/23
    Looks quite complicated, but works:
    RX "ADDRESS AMBIENT 'loaduri sys:?view=icon&mode=all'"
    Opens SYS: in icon/all mode.
    Please note the ' characters enclosing the loaduri command.
    So this is basically your line for external usage:
    RX "ADDRESS AMBIENT 'loaduri sys:?view=List&mode=ALL&top=180&left=240&width=540&height=740'"
  • »09.06.15 - 12:53
    Posts: 2220 from 2003/2/24
    I'd also use RXCmd instead or RX, because RXCmd doesn't need a working rexxsyslib.library installed and thus works out of the box on any MorphOS setup. It also makes the line to look a bit cleaner:
    RXCmd AMBIENT "loaduri sys:?view=List&mode=ALL&top=180&left=240&width=540&height=740"
    [ Edited by jPV 09.06.2015 - 17:30 ]
  • »09.06.15 - 13:30
  • rms
    rms
    Hi all,
    thanks for all your feed-back about this :-) Yes it seems to work, Frank did also suggest the same way to do that, I mean rexx and loaduri. I need to see now with MUIbase developper how I can use that in my database to open directly from within the db the partions and directories.
    Best regards
    Christoph
  • »10.06.15 - 02:32
