do we have a AVI - Cutting Software ?
    defender
    Posts: 249 from 2011/4/24
    Hi all together, do we have a tool to cut AVI files, like for example virtual Dub or manDVD ...
    maybe a command line tool ? anything ? we have an mp3 cutter that works fine for me.
    Such a tool for AVI's would be great.
    greets
  • »04.04.15 - 06:19
    Posts: 12554 from 2003/5/22
    > do we have a tool to cut AVI files, [...] maybe a command line tool ?
    FFmpeg and MEncoder are command line tools that can be used to cut video files.
  • »04.04.15 - 06:52
    Posts: 846 from 2007/10/23
    Did you try Blender?
    http://wiki.blender.org/index.php/Doc:2.4/Tutorials/Sequencer/Examples_2
  • »04.04.15 - 13:37
    Tom01
    Posts: 187 from 2009/9/20
    Does not support audio.
  • »05.04.15 - 00:12
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    Why not ?? Blender 2.4.6 on MorphOS support audio.
    I cut movies with Blender and audio,too.
  • »05.04.15 - 07:04
    pegasos-sigi2
    Blender 2.4.5 support audio, too.
  • »05.04.15 - 07:18
    igracki
    Posts: 471 from 2003/2/24
    You can also use mplayer/mencoder to cut a movie!
    Start mplayer with this additional argument "-edlout <filename for the edl file>".
    mplayer -gui 1 -edlout movie.edl movie.avi
    Then you have to press "i" at the start and at the end of the part which is to be cut out.
    To play a movie with an edl file
    mplayer -gui 1 -edl movie.edl movie.avi
    MPlayer then skips the parts which you defined with pressing "i".
    To cut the movie you need mencoder:
    mencoder -edl movie.edl -ovc copy -oac copy movie.avi -o movie_cut.avi
  • »06.04.15 - 10:46
    Tom01
    Blender 2.62 does not have audio support.
    Python-3.2 is installed, but Blender-2.46 does not run.
    [ Edited by Tom01 06.04.2015 - 16:00 ]
  • »06.04.15 - 12:02
  • vox
    vox
    Posts: 616 from 2003/11/24
    greets
    At this thread you can find some advices and scripts for FFMpeg
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7393&forum=9
  • »06.04.15 - 14:36
    igracki
    I installed Blender yesterday via Grunch and started it w/o any problems.
  • »06.04.15 - 15:13
    Tom01
    Look at the version numbers.
  • »06.04.15 - 15:21
    defender
    [quote] You can also use mplayer/mencoder to cut a movie!
    mencoder -edl movie.edl -ovc copy -oac copy movie.avi -o movie_cut.avi /quote]
    Thats easy and it works fine Thanks igracki :-)
  • »06.04.15 - 18:09
