Activate help key
    Posts: 847 from 2007/10/23
    Are you missing your old help key? Maybe you just want to call an AmigaGuide or bubble help.
    If you have a Mac keyboard and the key labeled help sends an insert code, you can configure Poseidon to get the right behaviour.
  • »25.03.15 - 13:29
    Posts: 2220 from 2003/2/24
    And if using a windows keyboard, the menu key between rcommand and right ctrl is mapped as Amiga's help key by default.
  • »25.03.15 - 14:50
    Cool_amigaN
    Posts: 777 from 2011/11/30
    @jPV
    Nice tip. Though mine is a Windows' keyboard the menu key wasn't mapped. I did it and now everything is fine :)
  • »26.03.15 - 09:59
