Odyssey & FREAK
    Posts: 843 from 2007/10/23
    Hi!
    Do you know if Odyssey's engine can also have FREAK attacks?
    http://en.wikipedia.org/wiki/FREAK
    Greetings,
    Stefan
  • »05.03.15 - 10:12
  • ASiegel
    Posts: 1397 from 2003/2/15
    Hello, you can test your preferred web browsers on the following website: freakattack.com
  • »05.03.15 - 13:34
    Posts: 12543 from 2003/5/22
    Current Odyssey uses OpenSSL 1.0.1g. Invulnerability requires at least version 1.0.1k (or 0.9.8zd or 1.0.0p).
    http://www.google.com/search?q=freak+attack+openssl+1.0.1k
  • »05.03.15 - 15:14
    Thanks André!
    "Warning! Your client is vulnerable to CVE-2015-0204. Even though your client doesn't offer any RSA EXPORT suites, it can still be tricked into using one of them. We encourage you to upgrade your client."
    see also
  • »05.03.15 - 16:59
  • ASiegel
    @ polluks
    Fortunately, running a vulnerable client is not enough. FREAK attacks can be prevented on the server level. The MorphZone forum is not affected by this particular issue, for instance.
  • »05.03.15 - 17:15
