DNG, a new public archival format for digital camera raw dat
    Posts: 979 from 2003/6/28
    Raw file formats are becoming extremely popular in digital photography workflows because they offer creative professionals greater creative control. However, cameras can use many different raw formats - the specifications for which are not publicly available - which means that not every raw file can be read by a variety of software applications. As a result, the use of these proprietary raw files as a long-term archival solution carries risk, and sharing these files across complex workflows is even more challenging.
    The solution to this growing problem? The Digital Negative (DNG), a new, publicly available archival format for the raw files generated by digital cameras. By addressing the lack of an open standard for the raw files created by individual camera models, DNG helps ensure that photographers will be able to access their files in the future.
    In addition to announcing the Digital Negative, Adobe announces the availability of the free Adobe DNG Converter (Windows® | Macintosh), which easily translates raw files from many of today's popular cameras. Software developers and manufacturers can download the complete DNG specification (PDF: 276k). DNG is supported by both Adobe® Photoshop® CS and Adobe Photoshop Elements 3.0 (Windows® | Macintosh) software.
    And MorphOS? :-)
    http://www.adobe.com/dng
  • »29.09.04 - 19:16
    The format is supported by more cameras...
  • »15.04.05 - 16:43
    NicePics13
    Posts: 63 from 2007/3/9
    10 years later :-) Tried to view some DNG and Nikon NEF (RAW) but just got the embedded thumbnails to show.
    CBM Amiga 1200 + 4MB AMITEK with 33MHz 68882 FPU
    PowerBook5,4 1024MB 1333MHz G4
  • »09.02.15 - 17:59
    Krashan
    Posts: 1107 from 2003/6/11
    Seems that major vendors of digital cameras decided to ignore this format. Then there is no point in wasting scarce MorphOS programmers manpower on it.
  • »10.02.15 - 18:34
    NicePics13
    I wouldn't say that, any pro level camera saves images raw. Then the photographer exports the final edit to whatever mainstream format they wish.
    What about the http://www.libraw.org/ library that applications like Darktable and I suppose Gimp use to decode?
  • »10.02.15 - 21:03
    Krashan
    I was talking about DNG.
  • »11.02.15 - 04:08
    In_Correct
    Posts: 245 from 2012/10/14
    Made by Adobe it is? Then it is silly. I understand why notbody supports it.
  • »11.02.15 - 11:21
    NicePics13
    Yeah, not even my photographer friends use that one :-D
  • »11.02.15 - 11:51
    Minuous
    Posts: 161 from 2010/2/12
    It should have been designed as an IFF FORM, then it would have had more chance for adoption. I hope they have learned this lesson now.
  • »14.02.15 - 03:34
