Posts: 1618 from 2012/11/9
I just tried v0.8, and it locked up my MorphOS system, and I had to totally reboot the system.
I tested Alice in Wonderland from epubBooks -
https://www.epubbooks.com/downloads/7-alice-in-wonderland .... and it showed some text dis-jointed from other text in Chapter III I seem to remember it was, and some text overlaid with an image or two, and probably other text not exactly as it should.
I also still notice words being split apart, such as an 'h' all on its own on a line, preceded by something like 'fis' - so this word should have been shown together as 'fish'. This is just an example of how words are not been kept together or properly hyphenated (-) so you can tell there is more of a word on the following line, but that method only usually is relevant, and should also ONLY work that way when there is a substantial part of a word that is either needing to be hypenated or is a usual word to be hyphenated, which 'fish' or other similar words do not fall into the category of.
I got the total crash when I tried to view the Liverpool map from:
http://www.ebookmaps.com/dw_epub2/Liverpool.epub .... and that showed the front page, and then my system froze up/locked, so I am not going back trying it again at the moment, until you can offer some greater optimism that my system will not lock up totally if I try it again.
[ Edited by NewSense 15.10.2014 - 23:21 ]MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.20+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
