Installation Error with Chrysalis Pack 3.7.1
    WeiXing3D
    Posts: 327 from 2012/6/13
    @Papiosaur
    I'm getting the following error while trying to install Chrysalis Pack 3.7.1, downloaded from link at meta-morphos.org:
    "Failed to fetch font "andale32." OWB WON'T WORK"
    After a little while the error cleared by itself and I was able to continue with installation. So is that a bug, or something that may affect the installation?
    In any case, after a very long installation, things seem to be working OK.
    Before I am asked, I'm installing on top of a fresh new installation of MOS 3.7, after I got my MacMini back from repair (broken optical drive).
    [ Edited by WeiXing3D 13.08.2014 - 19:11 ]
  • »14.08.14 - 00:27
  • esc
    esc
    Posts: 160 from 2013/5/27
    It looks like the font 'andale32' for OWB (web browser) wasn't available for a short time. I don't think it's a very important issue, or one that anyone can do anything about. You would have just been missing that font I believe, since you can use OWB without downloading all the custom fonts.
  • »14.08.14 - 03:46
    Brumiga
    Posts: 276 from 2004/4/3
    @WeiXing3D,
    I gave a try to download and install m$ truetype fonts. It seems that the script provided with owb encouters a problem to download them from http://downloads.sourceforge.net/project/corefonts/ . So I downloaded an old version of owb, before 1.10 for example, then I used the provided script and the truetype fonts were downloaded and installed successfully.
    So if you absolutly want/need the m$ truetype fonts to be installed onto your fresh installation of morphos 3.7 and chrysalis 3.7.1 do as I did.
    Brumiga
  • »14.08.14 - 11:36
