[rhLaunch] Kickstart not found
    noob
    Posts: 24 from 2012/10/17
    Hey guys!
    I am trying to use rhLaunch in connection with e-uae, but I have a problem concerning the kickstart files. Although I have set the path to the roms correctly, rhLaunch says that there are no kickstarts found. Any ideas??
    [ Editiert durch noob 19.07.2013 - 12:31 ]
    Mac mini G4 Silent-Upgrade - MorphOS 3.2 registered
  • »19.07.13 - 08:29
    Posts: 12572 from 2003/5/22
    In case you were trying with encrypted Amiga Forever Kickstart ROM files, this could help:
    http://morph.zone/modules/newbb_plus/viewtopic.php?forum=16&topic_id=10053&start=18
  • »30.05.14 - 20:31
    XzIt
    Posts: 250 from 2005/1/19
    maybe the files arent flagged as readable?
    right click the file and check info if its flagged or not, unzipping files leaves them unreadable dont know why, a bug ? =)
    X
  • »31.05.14 - 10:52
    Doesn't happen here using the XAD system for unzipping.
  • »31.05.14 - 11:03
    naTmeg
    Posts: 135 from 2004/2/8
    Version 0.7 is now available HERE. (MorphOS only)
  • »01.06.14 - 17:53
