Kaya glitch
    Robert
    Posts: 331 from 2003/5/12
    When listening to mp3s while browsing, every time I click a link, Kaya
    kind of farts, which is quite annoying.
    I'm using on-board sound.
    Anyone else experience this or know how to solve it?
    Robert.
  • »16.02.04 - 17:59
    liquidbit
    Posts: 408 from 2003/10/12
    farts ?
    what are you feeding him?
    :homer:
  • »16.02.04 - 18:04
    Robert
    Well it makes a strange sound. The best way i can describe it is that
    if Kryten from Red Dwarf farted, it would probably sound like that.
    Robert.
  • »16.02.04 - 18:09
    Posts: 607 from 2003/4/11
    If it happens with Voyager, it might be related to a bug that happens if no AREXX is available. Voyager disables multitasking for a while in that case afair.
  • »16.02.04 - 18:19
    Robert
    It is Voyager. Guess I'll just put up with it for now.
    Thanks anyway.
    Robert.
  • »16.02.04 - 18:28
    Golem
    Posts: 766 from 2003/2/28
    You can do that, but you could also try to get ARexx working. Have a look here.
  • »17.02.04 - 07:11
  • -D-
    -D-
    Posts: 118 from 2003/5/1
    Hi Robert,
    Voyager eats lots of CPU at times, which seems to
    cause some jitters in the onboard sound - on my system
    even with AREXX active. I suspect the problem is less
    noticeable on G4 systems.
    I bought a cheapish Sound Blaster "Live!" card, which
    finally solved the problem for me. The output quality
    is also far improved over the onboard sound (reduced
    noise, and better overall sound reproduction).
  • »18.02.04 - 06:42
    Robert
    @-D-:
    Sure but 600mhz?  :-o
    I did this too but recently swapped it out to my A1 as the onboard sound in the A1 doesn't work at all (and is never likely to, as far as I can tell.) This probably explains why I never noticed it before.
    I suppose I could buy another soundcard.
    Robert.
  • »18.02.04 - 06:50
  • -D-
    -D-
    --edit sp--
    @Robert
    According to TaskManager, it'll hit near 100% usage...especially
    when it's loading up big/bloated sites like ebay. The usage peaks
    seem to coincide with the sound jitters.
    I definately could be wrong, but it's my best guess! :)
  • »18.02.04 - 07:14
    Posts: 12 from 2003/8/7
    @ -D-:
    hey, how can you control your in/output leves with
    your sb-live card?
    I want the amithlon-mixer (v2.1) for my SB-live card, which mixer has you?
    Ciao MaSch
  • »18.02.04 - 11:43
    Robert
    @-D-:
    Isn't that really inefficient?
    Do other browsers behave like this?
    Robert.
  • »18.02.04 - 12:27
  • jah
    jah
    Posts: 69 from 2003/3/24
    hello Robert,
    it is kaya fault too, the "playtask" is at a lower priority than it
    should be, so it is excessively sensitive to the surrounding events
    this problem has been fixed
  • »18.02.04 - 15:09
  • -D-
    -D-
    @MaSch
    I haven't tried to mess with the levels yet, I just got
    the card the other day. If I find something that works I'll
    post it here. :)
    @Robert
    Nah, not really. The sound on my Athlon will skip in a
    similar way when I scroll through the window with IE.
    OSX browsers appear to me even worse. IBrowse is a little better
    than Voyager in this regard, but then again, Voyager is much
    faster. I don't think much of it is really even browser -
    centric, but just moving display data around in general is CPU
    intensive.
    I should also correct myself, Voyager on it's own won't peak
    at 100% usage, I meant "total" usage (like Voyager plus Kaya/
    AmiNetRadio/etc).
  • »19.02.04 - 00:48
