                Posts: 350 from 2003/10/12
				I'm getting around 4,5 - 5mb/sec between a Peg2/G4+MiamiDX+smbfs&samba2.0.7 and an AthlonXP2000+WinXP peecee. In both directions. It's a little bit funny that the Pegasos still has some CPU available at this speeds (load was 65-70% according to the MOS Taskmanager), while the peecee practically stopped, even the mouse cursor movement slowed down and became jumpy... ;)
In my other test, using the above Pegasos and an A2000/B2060/Ariadne/MDX+MNI driver/Samba2.0.7/smbfs system, i got around 550-600k/sec, also in both directions. (With large files. Small files can drop the speed down to around 50k/sec. This is caused by the single-threaded desing of smbfs i think, which practically kills the 060.)
Just a note, if you experience low speeds with MiamiDX, try to disable IP NAT in the TCP/IP -> LAN connect window, if you don't need that feature always, because on my 060 this helped to speed up transfers from 150-200k/sec to ~600k/sec, or even up to 750k/sec with FTP transfers. (Again, large files only.)
About stability issues, i'm experiencing absolute no crashes with MiamiDX, works very well both on my Pegasos and also on my 060. My A2000/060 currenly has 13+ days uptime, and she's in heavy  desktop use...
