transfer ftp and hidden folders
    Derringer
    Posts: 103 from 2008/8/4
    Dudes I have a problem, i have to acces an ftp server, but on the server the folders are hidden. Is there is a way to enter one of the hidden folders with transfer? (I know the subfolder name)
    MorphOS PowerBook G4 1,67GHz, 2GB Ram, 250GBHdd, ATI 9700/128MB
    Morphos G5 2,7GHz, 8GB Ram, 500GB Hdd, ATi Passive cooled 9800 PRO/128MB
  • »22.01.14 - 18:28
    Posts: 1099 from 2004/9/23
    What about, just entering them into the path string input?
  • »22.01.14 - 20:49
    Derringer
    already tried, not working. (Tried simple, with ".")
    [ Edited by Derringer 23.01.2014 - 00:37 ]
  • »22.01.14 - 22:36
    stefkos
    Posts: 102 from 2004/2/4
    I wil check that at home and write here or on your private mail.
  • »23.01.14 - 06:13
    Posts: 2220 from 2003/2/24
    Are you sure server is allowing you to do that?
  • »23.01.14 - 07:03
    Derringer
    Yeah, the admin guys said i can, but to be honest i He is not a very talkable guy, and most of the the not reachable...
  • »24.01.14 - 07:47
    stefkos
    I found solution for this problem, just need some tests.
    How do you think, this option should be avaiable by default? we need switch or.....?
  • »27.01.14 - 16:59
