nobrainer wrote:
I have just installed a fresh 3.4 and then the latest Chrysalis over it and now it all looks @#$@#%#$ up?!
After reboot, it did not find my desktop background picture, there is no WALLPAPERS folder in the Prefs folder anymore and there is no Skin available that I've chosen before, the Amiga OS4-ish one, what was it called, can't remember now.
The existing skin looks like very bad, the default skin NOX2 with bad blue/violet colors.. is that the default/normal one?
Please someone tell me something went wrong with the pack install, because I don't like this. There is no Chrysalis menu on the right click either, so something's fishy with this installation?
I did the re-install of both, the OS and Chrysalis, twice.. got the same thing... won't do it again until someone explains what is going on. :)
Thanks.
p.s. Right click on desktop also does nothing anymore, no popup menus to select etc... can hardly believe this is normal?!
Chrysalis usually changes a lot of the default settings, themes, icons, mui features, colors etc. I agree though, I spend ages restoring them all back to defaults/my preferences after installing.
I asked Papi if there could be an option in the next pack to just install the programs and not change settings, guess this didn't make it in?
[ Edited by danwood 28.12.2013 - 17:28 ]
