Any font editor out there ?
    droopy
    Posts: 35 from 2013/12/12
    Is there any font editor for morph os ?
    And what kind of fonts can be used/imported from other sources ?
  • »09.01.14 - 16:59
    connor
    Posts: 650 from 2007/7/29
    TypeSmith still works on MOS. But it is commercial. If you can find a copy then it might be useful: http://www.amigareport.com/ar311/tsreview.html . But in general you can use all Amiga bitmap fonts and TrueType Fonts from outside of the Amiga (TTF). There are so many free ones on the web which you can use that you maybe do not need to draw your own fonts.
  • »09.01.14 - 17:04
    bash64
    Posts: 977 from 2010/10/28
    TypeSmith handles postscript fonts.
    Its quite excellent.
    I love it.
    I have a very large library of postscript fonts for use with PageStream (DTP software).
  • »09.01.14 - 21:14
    droopy
    I love the fact there is a lot of fonts out there.. but most of them need to have the Swedish special chars added to the sets. And it is not to much problem to add if you have an font editor since the swedish chars are either an "O" with dots or an "A" with a ring or dots over it.
    So it's great to find a good font editor.. the alternative would be to edit fonts with an PC program and export them to MOS. But ofcourse it's more fun to do it on the original machine.
    Would any old amiga progam work ?
  • »10.01.14 - 04:16
    Posts: 12572 from 2003/5/22
    See previous replies in this thread.
  • »10.01.14 - 07:15
    Krashan
    Posts: 1107 from 2003/6/11
    @droopy:
    Is there any font editor for morphos?
    For bitmap fonts you can use Typeface (it is on Aminet).
  • »12.01.14 - 07:02
