Delitracker
    kickstart
    Posts: 227 from 2009/4/28
    Hi!
    On aminet delitracker is marked like morphos compatible but when i load a module computer freeze, where?s the problem? I need a mos compatible version?
    Thanks!
  • »26.10.09 - 18:59
    Posts: 919 from 2004/1/24
    IIRC you need to use the 14bit-Noteplayer by platon
    http://aminet.net/mus/play/Deli14BitGenie.lha
  • »26.10.09 - 19:39
    kickstart
    Just a txt fle?
  • »26.10.09 - 20:23
    dIGIMAN
    Posts: 273 from 2005/11/7
    http://platon42.de/index3.html should help
    [ Edited by dIGIMAN on 2009/10/27 1:30 ]
  • »26.10.09 - 21:21
    kickstart
    This is really annoying.
    I download it from the platon42 web site... but when configuring it my window is different.
    http://www.platon42.de/cgi-local/pic.pl?gfx/mus/deli14bit1.png&gfx/mus/deli14bit2.png
    On my prefs windown i dont see any AHI options by example, a x file.
  • »29.10.09 - 20:42
    guruman
    Posts: 462 from 2003/7/21
    Settings -> Genies
    Click on Paula-Noteplayer until you have a D on its side and on 14Bit-Noteplayer until you have an F. Then it works like a charm, at least for me!
    Kind regards,
    Andrea
  • »29.10.09 - 20:57
    kickstart
    I will try... again. =)
    Thanks.
  • »29.10.09 - 21:09
    kickstart
    Hi again
    guruman tips runs fine but the problem is the volume, delitracker start to play the module (seconds rise) but without any sound.
    Like i tell in my other post, deli14bit settings appears like incomplete (compared with the pic at platon website) i cant select the ahi source or any volume settings. Totally lost.
    Thanks.
  • »02.11.09 - 22:15
    gooseberry
    Posts: 9 from 2010/1/16
    [ Edited by gooseberry 24.05.2017 - 09:44 ]
  • »02.08.12 - 12:44
    Posts: 12572 from 2003/5/22
    > Use this guide: [...]. Please, take special care of paragraphs 5 and 6.
    What about paragraph 7? Timerhack is an OS4 executable as far as I can see. Is it (or something else with the same functionality) not needed on MorphOS?
  • »02.08.12 - 15:13
    gooseberry
  • »02.08.12 - 17:37
    > you need to skip this step, it's for AOS only. [...] I personally
    > had no timing problems with modules i played.
    I followed the steps (except #7) and DeliTracker works fine now on MorphOS 3.1 on my Mac mini G4. Thanks :-) I remember that I had read fingus' instructions back then when he posted them to amigaworld.net but silly me didn't even think to attempt to follow them due to mention of step #7.
    As I see there has already been a discussion on the timing issue (that is not there under MorphOS):
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=2094&forum=9&start=12
    And there's an ARexx script that's supposed to help with running on MorphOS:
    http://wickedvinz.free.fr/files/Delitracker2_MOS.lha
  • »08.08.12 - 14:34
    Intuition
    Posts: 1116 from 2013/5/24
    Call me stupid but I cannot for the life of me get Delitracker to play anything. It just flashes the screen titlebar red briefly when I hit play.
    I followed all the instructions in that aw.net thread but can't find where to tell the 14bit noteplayer to use AHI Unit 0.
    I installed the 68k rexxsyslib.library and that AREXX script you linked to, but it still doesn't do anything.
    Can anyone tell me where I'm going wrong? I suspect it's the AHI Unit thing but perhaps it's another problem?
  • »16.08.13 - 21:10
    For what it's worth I tried getting it to run again (been years), and after some fiddling (and crashes) it works with the following configuration:
    * Delitracker v2.34
    * 14-bit Noteplayer v4.30
    I deleted all other DeliTracker Genies and disabled Paula-Noteplayer. I configured the 14-bit Noteplayer (open the DeliTracker Genies window, click on the 14-bit Noteplayer, push the "Show" button and when the 14-bit Noteplayer window is open (and active) just press right mouse button to access the settings) to use 16-bit AHI as output (AHI Unit 0 16-bit stereo HiFi++)...and that's it really. You'll need to adjust the Mixing frequency in the 14-bit Noteplayer prefs or it'll sound horrible (and for some reason it wont save the settings) and there are still a lot of replay timing problems, but hey, just like I remembered ;-)
    Really, use UADE; it's way better.
    *edit: just tried out the AHI-Noteplayer (latest from Aminet) and that works as well. Still timing probs, but less so ;)
    [ Edited by Stevo 18.08.2013 - 21:25 ]
  • »18.08.13 - 17:13
    Intuition
    * Delitracker v2.34
    Thanks for the tips.
    I swear my brain is turning to mush because I cannot see anything that lets me configure the noteplayer to use AHI Unit 0.
    Screenshot here: http://imageshack.us/photo/my-images/13/er0p.png/
    I know UADE is better (I did the port to Haiku) but I'm just stubborn and want to get Delitracker working for the sake of it tbh. :)
    I'll try the AHI noteplayer from Aminet and see if it works for me.
  • »18.08.13 - 17:39
    Intuition wrote:
    * Delitracker v2.34
    Like I said "click on the 14-bit Noteplayer, push the "Show" button and when the 14-bit Noteplayer window is open (and active) just press right mouse button to access the settings".
    Screenshot here: http://imageshack.us/a/img19/4140/yj3f.png
    ok, that's of no use, but just activate that window and press right mouse button.
  • »18.08.13 - 18:56
    Intuition
    Stevo wrote:
    Intuition wrote:
    * Delitracker v2.34
    Cheers, got it working now. :)
  • »18.08.13 - 21:01
    neoman
    Posts: 33 from 2013/7/29
    Hello,
    because I had the same problem I patched the version of DeliTracker2 (from dt234.lha) to NOT add the Paula-NotePlayer to the Genies. So DT2 can now be run (after installing the AHI-NotePlayer for sure) to play modules directly without the need to delete the Paula genie first. I hope it will help some DeliTracker enthusiasts :-)
    So, just install DeliTracker with this manual (without step 6+7 now):
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=19458&forum=32&start=60&viewmode=flat&order=0#658172
    And the new executable is available here:
    http://www.localmindprovider.com/morphos/dt234-no-paula.lha
    Also, in MorphOS use HiFi 16bit stereo++. I had problems with the other units because they were mono ...
    Enjoy!
  • »03.12.13 - 20:18
