SCube and SZoom updates (1.1)
    kiero
    Posts: 129 from 2003/2/28
    Since MorphOS 3.0 fixes implementation of certain OpenGL functions it was necesary to update these apps. You can find both on http://kiero.binaryriot.org (scube-1.1.lha and szoom-1.1.lha).
  • »08.07.12 - 18:33
    Jambalah
    Posts: 820 from 2008/3/30
    Nice!!
    Thanks for those updates!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »08.07.12 - 18:36
    Daff
    Posts: 251 from 2003/4/5
    I use SZoom and it works now with MorphOS 3.1.
    But it's much slower than SZoom 1.0 on MorphOS 2.7.
    My setup :
    Power Mac MDD 1,83GHz.
    Radeon 9000 64MB.
    1500MB RAM.
    No Enhanced Display.
    http://obligement.free.fr
  • »10.07.12 - 03:31
    Posts: 655 from 2004/4/15
    scube is also much slower on 3.x than on 2.x. There seems to be something wrong with the new tinygl library.
  • »11.07.12 - 02:51
    Posts: 1390 from 2010/1/6
    Yes, useing the old tinygl.library gives normal speed........
  • »11.07.12 - 09:30
    _DaNi_
    Posts: 154 from 2010/5/4
    i test it scube, old version and new version and is very very slow here, Efika with MOS 3.1 but i think the problem is the tinygl.library becouse with MOS 2.7 the scube fly here (no slowly and no slowdowns)
    Tinygl.library from MOS 3.x is a lot more slowly here than tinygl.library 2.7 on my efika 5k2 system
  • »15.07.12 - 07:39
    serge
    Posts: 725 from 2003/2/20
    Scube displays trashed pictures on cube under MorphOS 3.2
    An Update coming soon?  ;-)
  • »28.05.13 - 18:01
    SoundSquare
    Posts: 1214 from 2004/12/1
    i noticed the same with the "feather" blanker, it's trashed (powerbook), and also Mawi and some other warp3D demos don't work (no rave3D driver found)
  • »28.05.13 - 19:43
    Posts: 12572 from 2003/5/22
    Sounds like R300 3D support doesn't include Goa/Rave3D, just TinyGL. Pity if true.
    Addendum:
    Apparently true: https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9251&forum=3
    Confirmed by MorphOS Team member:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9256&forum=49&start=4
    [ Edited by Andreas_Wolf 31.05.2013 - 00:34 ]
  • »28.05.13 - 21:03
