fullscreen button owb
    amiga4001
    Posts: 454 from 2006/11/16
    Yes I know another owb question...
    I used to have a fullscreenbutton when I spoofed as Ipad on youtube now not anymore?
    There is a script which is called fullscreenfix and flasplugin is enabled and at its place.
    I also registered as html5 tester at youtube.
    Any idea's I am on latest owb 1.20
  • »20.05.13 - 17:40
    cip060
    Posts: 153 from 2010/7/30
    F11!!!!!
  • »20.05.13 - 18:25
    Posts: 12572 from 2003/5/22
    It's still there, and it works. Problem is that it doesn't use overlay mode anymore so replay gets unbearably slow, though.
    This doesn't work in Youtube's "mobile" mode unfortunately.
    > flasplugin is enabled and at its place. I also registered as html5 tester at youtube.
    None of that helps when spoofing as iOS device.
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=9130&start=27
  • »20.05.13 - 21:55
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    There's no need to spoof as Ipad to watch youtube anyway. Youtube.js does an equivalent job to replace contents with HTML5.
    I'll see if something can be done about the fullscreen button in ipad mode, though, just in case.
  • »21.05.13 - 03:38
    Thanks, very kind.
  • »21.05.13 - 06:38
