Chrysalis - is it just me..or does it not work?
    TheMagicM
    Posts: 1220 from 2003/6/17
    Just like the subject says..
    Clean install of MorphOS 3.1, followed up by Chrysalis install. rhLaunch doesnt come up, none of the emulators..havent went thru the menus to see what else works or doesnt. I got rhLaunch to come up by editing the menu but for the most part, it seems broken.
  • »14.05.13 - 13:36
    Yasu
    Posts: 1724 from 2012/3/22
    Strange. It worked for mw without a glitch. Several times even.
    My MorphOS blog
  • »14.05.13 - 13:40
    TheMagicM
    @papiosaur : that I did. I'll reinstall. Thanks!
  • »14.05.13 - 15:40
    TheMagicM
    That took care of it.. side note..do you have "release notes" ? That way I can see whats different between what I *just downloaded* yesterday and your release today?
  • »14.05.13 - 21:25
    Posts: 12543 from 2003/5/22
    http://www.meta-morphos.org/article.php?sid=1541
  • »14.05.13 - 21:42
    TheMagicM
    hmm... yes..but something that says..
    ACE updated from 1.4 --> 1.5 etc.
    Can this be used to upgrade the previous version without breaking anything?
  • »14.05.13 - 21:44
    Papiosaur
    Posts: 2591 from 2003/4/10
    citation:
    "it must installed just after clean installation MorphOS 3.1 (registered or not)"
    If you want to upgrade your old version of the pack Chrysalis (3.1.1 for example), you must use Grunch to updrade your software or do that at the hand.
    sorry, there is many many changes between versions (not listed as Polynet bar prefs: Scribble icon has been added) and you risk to breaking something if you install pack Chrysalis on your old version (prefs, etc...).
  • »15.05.13 - 03:14
