"First Contact" AmigaOne X1000 arrives
  • vox
    vox
    Posts: 616 from 2003/11/24
    redrumloa wrote:
    > TWO GRAND for a motherboard!?!?
    There's no surprise to that. If you take the well known X1000 system price and subtract what case, graphics card, RAM, HDD and optical drive are worth, that's where you arrive at.
    I am replying some months later, but I doubt the price increased since the post I am replying to.
    It isn't two grand, it is THREE GRAND for a motherboard which under performs a $30 Raspberry Pi.
    1775 British Pound Sterling equals
    2965.49 US Dollar
    That is before shipping.
    Nuttier than a fruitcake. But hey, a sucker is born every day is what P. T. Barnum (allegedly) used to say.
    Its about dual Athom based computer, or kind of dual Sempron 1.8Ghz in AMD terms - that is when its fully used in Linux.
    Surely, made in small quantities, means expensive.
    In PPC comparison and real use (e.g. Blender) its about G4 1.5Ghz when both cores are used.
    http://amigaworld.net/modules/newbb/viewtopic.php?mode=viewtopic&topic_id=35671&forum=34&start=140&viewmode=flat&order=0
    Here is an openbenchmark (Phoronix) results under Linux
    http://openbenchmarking.org/result/1310106-AR-AMIGAONE027
  • »13.08.14 - 13:00
    Posts: 12556 from 2003/5/22
    > Surely, currently most expensive board in the universe.
    Many Freescale boards are more expensive:
    http://www.freescale.com/files/32bit/doc/brochure/PWRARCHQIQSG.pdf
  • »13.08.14 - 19:13
    > It isn't two grand, it is THREE GRAND [...]. 1775 British Pound Sterling
    ...is even less than two grand. Maybe you shouldn't assume that non-US people use US Dollar as base currency.
    For the most part (i.e. everything bar video transcoding) it doesn't.
  • »13.08.14 - 19:23
  • vox
    vox
    Thanks for the info. Well that could be used as nice argunent to justify the future Cyrus price :-) Well see.
  • »13.08.14 - 20:35
    KimmoK
    Posts: 102 from 2003/5/19
    My summary:
    http://amigaworld.net/modules/newbb/viewtopic.php?mode=viewtopic&topic_id=35671&forum=34&start=160&viewmode=flat&order=0#665666
    "112s blender 2.62 PA6T 1.8Ghz Dualcore (LinuxMint)
    113s blender 2.62 G4 1.8Ghz DualCPU !"
    So PA6T is 2x faster than single G4.
    @PA6T vs Pi performance
    Pi performs like ~300Mhz Pentium2.
    PA6T performs like 1.8Ghz Pentium2 per core. (very roughly)
    (the problem beside x1000 price is that so far AOS4 utilizes very little of the performance of x1000 system. It uses less than 50% of CPU power and none of the 3D power or video acceleration.)
    @Cyrus price
    Now when 4...24 core PPC dev boards can be bought below eur2000, I think Cyrus should also be priced closer to those.
    [ Edited by KimmoK 14.08.2014 - 09:26 ]
    :-x  :-P  8-)
  • »14.08.14 - 06:07
    > 24 core PPC
    It's 12 dual-threaded cores.
  • »14.08.14 - 14:12
  • vox
    vox
    My summary:
    @Cyrus price
    Completely agree. In modern day terms its about Sempron/Celeron performance. Not so bad either, but downside is OS4 usess very little of it. Especially that PA Semi strenghts aren`t in CPU Power but in fast memory access. a bit better FPU performance and quite modern features for the time CPU was released.
    (Six execution units including a double precision FPU and Altivec unit
    Hypervisor and virtualization support, SGMII, Offload engine for cryptography, RAID, TCP)
    Surely, as name suggests its more power efficient than power in today terms.
  • »14.08.14 - 16:38
