MC68060FE133
    Posts: 12085 from 2003/5/22
    > I wonder if more than one Natami CPU daughtercard was assembled?
    Assuming you refer to "MC68060FE133" CPU boards here (there are others, also with full 68060RC chips), click the second last link I provided* and your question should be answered.
    * https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7819&forum=11&start=2
    > alternative socketed 68060 chips are still available to purchase for their designs
    Yes, but none of them claims to be able to run reliably at 133 MHz. Motorola/Freescale have only been guaranteeing clock speeds of up to 75 MHz for EC and LC parts and 60 MHz for full parts. If a hobbyist thinks that even the (about) 100 MHz that a full 68060 Rev.6 is overclockable to is not enough for his project he might be inclined to try a part that claims to run reliably at 133 MHz without overclocking.
  • »06.06.11 - 04:00
    Correction:
    > it seems the NatAmi Team's "MC68060FE133" still wasn't even tried at
    > more than about 80 MHz.
    Apparently, and I'm ashamed to admit, I missed that in the NatAmi forum thread I previously linked to the "MC68060FE133" was indicated running at about 100 MHz (101.5...103.3 is what I calculated based on known 68060 figures) already eight days ago. However, that's still a significant underclocking from alleged 133 MHz.
    Today it was indicated on another NatAmi forum thread that the "MC68060FE133" is running at about 120 MHz (120.0...122.1 is what I calculated based on known 68060 figures) now. When will we see 133 MHz? :-)
    http://www.natami.net/knowledge.php?b=1¬e=39600
    [ Edited by Andreas_Wolf 06.06.2011 - 13:57 ]
  • »06.06.11 - 12:12
    Well, I guess the question becomes how do we verify these figures?
    Not that I don't trust that group, but if they've managed to get those speeds they're not going to want to talk about it.
  • »06.06.11 - 14:15
    You think BigGun might be a crook? Now come on... ;-) I don't think the SysInfo screenshot is doctored. What we don't know though is how reliably the chip runs at 120 MHz. It can do a brief benchmarking, but can it run under full load for hours at 120 MHz?
    Yes, the faster a physical 060 chip can go on the NatAmi the smaller the performance advantage of their self-developed N68050/N68070 FPGA implementation is going to be.
  • »06.06.11 - 14:36
    This also does not eliminate the possibility that these are re-labeled chips.
    Without an MMU or FPU these could be easier to overclock.
    It would really hurt to know that the Chinese figured this out and it never occurred to the of us.
    But surface mount chips aren't something a hobbyist would normally consider (when there are socketed alternative).
    You did notice that the Sysinfo screens did seem to indicate a lack of MMU and FPU functions, didn't you?
    The lack of floating point functions is a significant minus for some software.
    This whole mystery just just murkier the more its examined.
    [ Edited by Jim 06.06.2011 - 15:27 ]
  • »06.06.11 - 14:46
    > This also does eliminate the possibility that these are re-labeled chips.
    Does it? A full 68060 Rev.6 can be overclocked from 50 or 60 MHz to just over 100 MHz. That's 70+% overclocking. Running a 75 MHz part at 120 MHz only amounts to 60% overclocking. Even running at 133 MHz amounts to no more than 78% overclocking.
    What do you mean "overclock"? Attempting to run the part past 133 MHz? Running a 133 MHz part at 120 MHz ist *under*-clocking, assuming the "possibility that these are re-labeled chips" is eliminated.
    Yes, but are there any socketed alternatives to a 133 MHz 060FE? Anything like an 68(EC)060RC133?
    Of course I did. Or how do you think I concluded it's the "MC68060FE133" board he ran SysInfo on?
  • »06.06.11 - 15:01
    No, No, No. That's an error/typo.
    It should be
    >What do you mean "overclock"? Attempting to run the part past 133 >MHz? Running a 133 MHz part at 120 MHz ist *under*-clocking, >assuming the "possibility that these are re-labeled chips" is >eliminated.
    No, I'm still pretty sure these are re-labeled chips. So over, not under.
    >Yes, but are there any socketed alternatives to a 133 MHz 060FE? >Anything like an 68(EC)060RC133?
    That 133 designation is really getting to you, isn't it?
    Its fiction. And no, there are no EC parts with 133 speed ratings (and, for that matter,there are no FE chips rated to 133).
    If the Natami team supports this fiction, then they may offend Freescale.
    [ Edited by Jim 06.06.2011 - 15:33 ]
  • »06.06.11 - 15:26
    Ah okay, thanks for clarification.
    Okay, I fell for your error/typo here obviously.
    I was arguing from a "does eliminate the possibility that these are re-labeled chips" standpoint here.
    I'm well aware of what Motorola/Freescale chips are rated to.
    I think the NatAmi is and will forever stay way below Freescale's radar level. Besides, the consumer version isn't supposed to have a physical 060 chip anyway.
  • »06.06.11 - 15:45
    From a NatAmi Team member in the previously linked thread:
    "It's currently running stable at 120mhz."
  • »06.06.11 - 16:44
    Time to figure out an adapter for CSPPCs and other accelerators that have socketed 68060s.
    But then again, the lack of an fpu is somewhat crippling.
  • »06.06.11 - 16:53
    If the "MC68060FE133" is a rebadged MC68EC060FE75 that is able to run overclocked at 120 MHz then an MC68EC060RC75 (which wouldn't need an adapter) should do as well, shouldn't it?
  • »06.06.11 - 17:04
    That would be worth exploring. I wonder if a custom math library could be created to make up for the loss of the fpu and how much of a performance hit that that tactic would create?
  • »06.06.11 - 17:15
    boot_wb
    Posts: 874 from 2007/4/9
    Jim,
    For that matter, there are no 68060 chips in FE packaging, at least according to Motorolla's (albeit Q4 2001) product selection guide.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »06.06.11 - 17:28
    @ boot_wb
    There are FE packaged 68060s, but this 133 designation is oh so dubious.
    Oh and get this, while I'm used to a few inaccuracies in Freescale listings, "Additional Features Floating Point Unit (FPU) Memory Management Unit (MMU)", their MC68EC060RC75 listing credits the processor with two features it doesn't have.
  • »06.06.11 - 17:33
    There are:
    http://www.google.com/search?q=site:freescale.com+mc68060+cqfp
  • »06.06.11 - 17:48
    Put out feelers for EC chips from distributors within the US (still a little scared of Chinese suppliers).
    I should have quotes by tomorrow.
  • »06.06.11 - 17:50
    Freescale recommends http://www.rocelec.com for the MC68EC060RC75 and says they have inventory of "> 1000" of this chip.
  • »06.06.11 - 18:02
    Wow! I couldn't get that link to work.
    Thanks Andreas.
    That quantity leaves some room for price negotiation.
    [ Edited by Jim 06.06.2011 - 18:11 ]
  • »06.06.11 - 18:10
    Direct link to all their 060RC chips:
    http://www.rocelec.com/about/searchresults/060rc/
    There're 1480 pcs. in stock currently. Seems they're differentiating manufacturer between Freescale and Motorola Semiconductor.
  • »06.06.11 - 18:29
    Thanks Andreas,
    I asked them for a price quote too.
    edit - A company called US Bid just contacted me. They should have a price by tomorrow (although they also gave me a quote on HD6309EPs I'd been looking for).
    [ Edited by Jim 06.06.2011 - 23:28 ]
  • »06.06.11 - 21:10
    Well, even after a call from US Bid yesterday, no one has sent me any prices yet.
    I really expected that at least Rochester Electronics (Freescale's recommended vendor)would get back to me.
    Guess I'll give it a few days.
    It's not vital anyway as I don't have anything to test it in (the only 68K based system I've still own has an '030 in it).
  • »08.06.11 - 02:59
    Posts: 2794 from 2006/3/21
    Only one of the suppliers I wrote to has responded so far, first with only a question of how many I needed, and then the second reply said that they did not have any available.
    I wonder if they became "not available", because I was also asking for where they came from, since Freescale claims they are not valid Motorola, or Freescale parts, and also asked if they had an MMU & FPU?
    Could be they decided they were not able to supply them because of the MMU & FPU requirement I imposed on the quote.
  • »08.06.11 - 06:51
    I've received similar responses from Chinese suppliers. (asking how many were needed)
    I don't think they can meet the one requirement you made, as the Natami team's Sysinfo posts show that the "FE133" they have doesn't have an MMU or FPU.
    Thomas does claim to have received a stock pile of these though, so they must intend to build some '060 boards with them.
    Still no luck on the EC components. I'll re-issue inquiries later today.
  • »09.06.11 - 10:32
    > have an MMU or FPU.
    This was already shown almost two years ago with another software (see the last link therein).
  • »09.06.11 - 11:59
    AyoS
    Posts: 410 from 2003/8/13
    Over the past couple of years I've bought chips direct from Chinese Manufactures... If you sent your quote request to enough companies you will definitely get multiple quotes... I've found that sometimes only one company has the chip and 20 companies will send me quotes based on what they think they can get out of me after paying the "one" actual company that has stock. always worked for me to be patient and go thru all the quotes... especially for older chips that may not be currently manufactured.
  • »10.06.11 - 03:32
