ARM for the future?
    Posts: 12079 from 2003/5/22
    > Morphos should work on cortex A15 un bigendian ;-)
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7675&start=522
  • »04.02.15 - 23:11
    Raf_MegaByte
    Posts: 430 from 2004/10/10
    ausPPC wrote:
    http://www.raspberrypi.org/raspberry-pi-2-on-sale/
    I think that UDOO is the most powerful of its category and also price/performance ratio is good as long as it is a Raspberry Pi dual or quad core, with 1 GB RAM DDR3 joint with Arduino microcontroller board.
    It is good as standalone and laptop too, as it features also LVDS connector and battery connector.
    http://www.udoo.org
    Features:
    - Freescale i.MX 6 ARM Cortex-A9 CPU Dual/Quad core 1GHz
    - Integrated graphics, each processor provides 3 separated accelerators for 2D, OpenGL® ES2.0 3D and OpenVG™
    - Atmel SAM3X8E ARM Cortex-M3 CPU (same as Arduino Due)
    - RAM DDR3 1GB
    - 76 fully available GPIO
    - Arduino-compatible R3 1.0 pinout
    - HDMI and LVDS + Touch (I2C signals)
    - Ethernet RJ45 (10/100/1000 MBit)
    - WiFi Module
    - Mini USB and Mini USB OTG
    - USB type A (x2) and USB connector (requires a specific wire)
    - Analog Audio and Mic
    - SATA (Only Quad-Core version)
    - Camera connection
    - Micro SD (boot device)
    - Power Supply 12V and External Battery connector
    [ Edited by Raf_MegaByte 06.02.2015 - 13:04 ]
  • »06.02.15 - 11:59
    > UDOO [...] is a Raspberry Pi dual or quad core
    What does that mean?
  • »06.02.15 - 17:13
    Raf_MegaByte
    UDOO is based on Raspberry Pi motherboard but powered with a CPU dual or quad core ARM Cortex (not to mention DDR3 RAM).
    Raspberry still is only dualcore on any model..
    [ Edited by Raf_MegaByte 06.02.2015 - 19:26 ]
  • »06.02.15 - 18:25
    I doubt this is true. What makes you believe that?
    There is no dual-core Raspberry Pi. The new version 2 is quad-core, all older models are single-core.
  • »06.02.15 - 20:53
    Frankly, after examining the really poor state of open video drivers for ALL ARM devices, and the poor documentation of their GPUs, at this point I'd rather stay with PPCs and discrete video cards.
  • »07.02.15 - 20:09
    ausPPC
    Posts: 543 from 2007/8/6
    And yet it moves... I mean, linux works on it just fine.
  • »07.02.15 - 21:55
    Raf_MegaByte
    For example this article on Tom's Hardware Italy:
    http://www.tomshw.it/cont/news/udoo-unisce-rasperry-pi-e-arduino-per-cambiare-il-mondo/44936/1.html
    It titles UDOO mix Raspberry pi and Arduino.
    Really? I thought at least they upgraded all the models to dual. What a pity it is mainly single core.
    Good to hear that version 2 is quad!
  • »08.02.15 - 16:28
    > For example this article on Tom's Hardware Italy: [...]
    Whatever the article claims, UDOO may be similar in functionality to Raspberry Pi plus Arduino, but it's certainly not based on Raspberry Pi. As far as I can see (via Google translator), the article fails to mention in what way exactly UDOO should be based on Raspberry Pi.
    The pre-2 models all used the same single-core SoC.
  • »08.02.15 - 17:30
    minator
    Posts: 365 from 2003/3/28
    The AMD dev board supports discrete cards.
  • »09.02.15 - 21:18
    minator
    This sounds interesting, they want to standardise ARM dev boards.
    A 64bit octa-core for $129 isn't too shabby either!
    https://www.96boards.org/
  • »10.02.15 - 01:22
    Worth noting.
    Got any references?
  • »11.02.15 - 12:49
    > Got any references?
    "PCI Express connectors configurable as a single x8 or dual x4 ports "
    http://www.amd.com/en-us/press-releases/Pages/amd-to-accelerate-2014jan28.aspx
    http://www.amd.com/en-us/press-releases/Pages/64-bit-developer-kit-2014jul30.aspx
  • »11.02.15 - 16:12
    Great, Opteron server processors.
    That explains that.
    No built in gpu.
  • »12.02.15 - 23:22
    > "Skybridge" (products available 2015)
    "CEO Lisa Su has commented that AMD has decided to change their focus away from Skybridge based on customer feedback. Customers were telling AMD that they didn't necessarily need socket compatible solutions, so AMD is going to work on differentiated solutions."
    http://www.anandtech.com/show/9231/amds-20162017-x86-roadmap-zen-is-in
    > "K12" (products available 2016)
    "With AMD having opted to prioritize Zen development, K12 has been pushed back from 2016 to 2017, essentially taking the near-simultaneous launch of the two parts off the table. AMD for their part is attributing this change in schedule only to the decision to focus on Zen, however with Opteron A1100 delayed, it’s entirely possible this is also a knock-on effect that has pushed back the entire AMD ARM roadmap."
    http://www.anandtech.com/show/9232/amds-k12-arm-cpu-now-in-2017
  • »08.05.15 - 14:27
    Well, that makes a lot of sense.
    I didn't really understand what they thought they would gain with socket compatibility.
    Changing ISAs with a cpu swap would present SO many issues that I wouldn't try to go that route.
  • »08.05.15 - 15:19
    The Freescale Roadmap shown in that first document is not encouraging for future PPC development.
    The Qorlq family shifts to primarily ARM processors and the only PPC core left in the furthest part of the forecast is the e6500.
    So our current ISA narrows to limit our choices, but they are not bad.
    And in the future ARM dominates. Good information to base decisions on our current direction(s).
  • »14.07.15 - 17:21
    Yasu
    Posts: 1724 from 2012/3/22
    Isn't a switch to AMD, like, confirmed?
    My MorphOS blog
  • »15.07.15 - 13:20
    I do not remember hearing about that.
    Sounds like an ask Andreas moment.
    AMD processors with built-in gpus would make as much sense as any other choice.
  • »15.07.15 - 16:04
    Yasu
    @Jim
    I beat him to it :-D
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&post_id=118409&viewmode=flat&sortorder=0&showonepost=1
    My MorphOS blog
  • »15.07.15 - 16:46
    AMD64 *ISA* doesn't necessarily mean AMD :-)
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=11&topic_id=11137&start=19
  • »15.07.15 - 17:26
    OK!
    I must remember to read entire threads.
    No Macs is cool with me.
    And I have been using AMD processors in most of my X86 systems since the K6-III+ was introduced.
    So we have the e5500 cored processors to look forward to support for in later revisions of our current OS (and with the e6500, a possible direction further).
    And AMD's APUs can provide the base for the new branch.
    Cool.
    A new lightweight OS that isn't weighed down by legacy crap, that IS morphing to something better.
  • »15.07.15 - 18:08
    Posts: 2794 from 2006/3/21
    Jim wrote:
    OK!
    Cool.
    As Andreas Wolf mentioned, AMD64 does not mean AMD CPU's, or APU's, it could mean Intel chips as well, that use the AMD64 ISA.
  • »15.07.15 - 19:49
    amigadave wrote:
    Jim wrote:
    OK!
    Cool.
    Good point David, AMD did lead the move to 64 bit.
    Although I tend to use X86-64 or X64 to differentiate this from X86 32 bit.
    After all, it is just an advance on an Intel ISA.
    Makes you wonder what hardware they will adopt.
    If the past is any kind of indication, we may not get that much warning.
    Still, I am looking forward to the X5000.
    What happens after that...well it will have to be judged on its own merits.
    Hopefully, the NGNG OS will incorporate some of the elements (outside of legacy compatibility) that make MorphOS stand out (compact/tight coding, micro kernel, etc).
    [ Edited by Jim 15.07.2015 - 15:18 ]
  • »15.07.15 - 21:14
