X1000
    Frankly, under Windows, which is a memory wasteful OS having more than 3.5 GB is very useful, I have a copy of Win7 64 with 8 GB of ddr2.
    Secondly, assemble language is still more efficient than C. Using it on a RISC processor is far easier than a CISC (X86). The number of instructions available on an X86 has becomeinsane.
    Just because you don;'t want to use assembly, doesn't mean I don't. The most efficient code I wrote on the 68K was in assembly, PPCs still make this of possibility under MorphOS.
    Never mind the huge amount of resources need for the conversion.
    To hell with X86, give me Titan!
  • »25.06.10 - 04:36
    Posts: 1516 from 2003/2/24
    I have to disagree. It does not really matter if you shave few instructions off from assembly routine. It is more important to optimize at algorithm level and there higher level languages are better.
    I wouldnt call PPC asm easy either. Coding on 68k asm was easy, I did that many years before MorphOS, but PPC RISC architecture is load/store architecture where you have to write lot more instructions to do same.
    C is way to go.
  • »25.06.10 - 07:39
    Would you like a complete list of the X86 instruction set including additions by both AMD and Intel? As far as I can tell, its the largest instruction set of any microprocessor series.
    As to the RISC instruction set of the PPC, simplified instructions were supposed be part of the advantage of the RISC approach.
    And I wouldn't have called 68K assembly easy, just easier.
  • »26.06.10 - 02:17
    feanor
    Posts: 104 from 2009/3/20
    @Jim
    itix is right. Algorithm optimization is way more important than assembly optimizations. Sure, these are important too, but only when the compiler doesn't do a good job there, eg. with ppc instructions like eg. cntlzw which doesn't have a C equivalent -ie. no C instruction/group of instructions get translated to this asm instruction, or when the compiler messes up scheduling -not very often, but it happens. Otherwise, it's just a waste of time just to achieve a 2-5% speed increase.
  • »26.06.10 - 10:12
    No thanks. I dont code with assembler any more. Occasionally I check how my code looks in asm when trying to optimize tight loop but other than that it is irrelevant today.
    PPC instructions are easy to understand (though may look cryptic for beginner) and I dont have problem reading disassembly but writing code in PPC asm is tedious... I mean you need many steps to do simple var++ thing and ponder if you should keep var in registers or not...
  • »26.06.10 - 15:22
    amyren
    Posts: 219 from 2010/5/15
    Rajinder wrote:
    @mos developers
    if that t-dick bloke were to supply an x1000 would you consider porting mos to the machine.
    or would that just be a no no ?...
    (i did read in a ami org forum, that the dick bloke would be up for it been porting over)
    i know people say about the price of it, but how much was the amigaone and peg boards new
    About that "t-dick bloke"...
    Just reading the recent interview with Trevor Dickinson.
    Apple is mentioned, and he stated he doesnt like Apple. He does have an Apple product, but with MorphOS on it :)
  • »30.06.10 - 10:07
    Posts: 12079 from 2003/5/22
    Yes, it has been known for years that he likes and uses MorphOS.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7186&forum=11&post_id=74362#74362
  • »30.06.10 - 10:40
    jcmarcos
    Posts: 1178 from 2003/3/13
    I remember a certain "trevordisk" user, maybe even here, in MorphZone. Then, why sending his investors down the AmigaOS route, which is inferior MorphOS? Thes "tha brand" have that much power?
  • »30.06.10 - 11:52
    I take it you mean "trevordick", not "trevordisk". And you're right, he's been a MorphZone member since October 2005:
    https://morph.zone/userinfo.php?uid=1754
    And yes, it was somewhat stupid from me to refer to his amigaworld.net postings when the evidence is right here on MorphZone ;-)
    I don't know his motivation for preferring OS4 over MorphOS in this regard. It might have to do with brand recognition, yes. You have to keep in mind that according to Dickinson the X1000 endeavour started in 2007, i.e. way before the release of MorphOS 2.0. And I think you remember how MorphOS development was publically perceived back then.
    Btw, his stance on the MorphOS pricing strategy (150 EUR per licence back then and before availability of Mac G4 version, though):
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=6316&forum=3&post_id=63311#63311
  • »30.06.10 - 12:51
    SoundSquare
    Posts: 1213 from 2004/12/1
    though he's not a diskhead i still don't want him to suck my disk.
  • »30.06.10 - 13:12
    > If MorphOS moves to the X86 platform, I will stay with Windows.
    In a recent interview Pascal "phoenixkonsole" Papara (the man behind AresOne and AROS distribution Broadway) told:
    "On the Amiga Event in Essen someone told me that even the MorphOS Team said they will stop using PowerPC in 2013."
    http://obligement.free.fr/articles_traduction/itwpapara_en.php
    Would be interesting to know who this "someone" was and if this "someone's" alleged statement resembles the truth in any way. Maybe the MorphOS Team can clarify if there really ever was such definite thing (like "2013") said by them.
  • »03.08.10 - 22:34
    Clearly a statement that requires a response.
    I'd hate to have devoted this much time to PPC systems if there is such a time table.
    Any developers (especially those who were at Essen) care to comment?
  • »04.08.10 - 02:13
    amiades
    Posts: 231 from 2005/6/2
    Perhaps 2012's "End of the world" is the reason? xD Only Amiga 2000s will survive thanks to their 2mm metal case.
  • »04.08.10 - 07:13
    jcmarcos
    Jim wrote:
    "someone told me that even the MorphOS Team said they will stop using PowerPC in 2013"
    Your could easily put your hate aside if, in the end, you get a better computer to run your favourite software on. Being "better computer" defined as faster, with more functions, cheaper and widely available. PowerPC processors are nice, of course, but not enough to tie a life to them. We'd already made that mistake with the original Amiga chipset. Many of the ones surviving suffer no hate after replacing them with regular components, driven by regular buses.
    Now, let's face the idea of porting such a tight operating system and drivers to, say, 1,000,000 possible combination of pieces that people call "PC". Even if the MorphOS Team is a small crowd of geniuses, I'd be terrified at that scenario.
  • »04.08.10 - 07:30
    Get27
    Posts: 90 from 2004/8/23
    It's logic, when all interesting PowerPC Mac will be supported, it will be the end.
    So, it will be time to switch again (we have ever switched from 68k to PPC).
    No problem for me, i will follow.
    [ Edité par Get27 le 4/8/2010 13:32 ]
    PowerMac 3.5, G4 1.0GHz DP, 1GB ram, 80GB HD + NAS, Radeon 9600 128MB Mac, 1680x1050
    PowerMac 7.3, G5 2.3GHz DP, 4GB ram, 160GB HD + NAS, Radeon 9800 128MB PC, 1680x1050
    Amiga 500+, Vampire 500v2+, HxC Floppy
  • »04.08.10 - 11:31
    Posts: 2794 from 2006/3/21
    In 2013 we and the MorphOS Team won't have to worry about which computer architecture we will all be using because according to the Mayan calendar and Nostradamus we are all going to be dead because the World is going to end in December of 2012. :lol:
    If no other more interesting computer platform is invented before then (which is not likely unless it is already in development now and almost ready for production), I have no problem with the MorphOS Team porting to x86/x64 hardware. If/when they do such a switch to x86/x64, I think they should pick a few specific sets of mobo's and components to support, or just support the same hardware that AROS is supporting, instead of trying to support too many different combinations and spreading themselves too thin. Quality over quantity with perhaps at least one low end configuration and one high end workstation supported so people can choose which one they want to buy.
  • »04.08.10 - 11:55
  • ZB
    ZB
    Posts: 115 from 2008/9/29
    I will follow also...
    Morphing the Phoenix...
  • »04.08.10 - 12:04
    That's a common misconception regarding the implications of the Mayan calendar. See:
    http://en.wikipedia.org/wiki/2012_phenomenon#Mesoamerican_Long_Count_calendar
    http://en.wikipedia.org/wiki/Mesoamerican_Long_Count_calendar#2012_and_the_Long_Count
    And I'm not aware of Nostradamus having said anything about 2012.
  • »04.08.10 - 13:24
    > Clearly a statement that requires a response. [...] Any developers (especially
    Unfortunately no public comment from any MorphOS Team member yet (unless I missed something). But there's some more info from Pascal Papara:
    http://www.amiga-news.de/de/news/comments/251888.html (German)
    Paraphrased: This "someone" who told about the alleged MorphOS 'roadmap' is no MorphOS Team member himself. He was a normal guest at Essen, wearing a "MOS-Team-shirt"(*). And he is a regular visitor of geit's hardware meetings.
    (*) I guess Pascal means "MorphOS T-shirt", without the "Team" part.
    As long as the MorphOS Team stays silence on this matter the only way to know more about that curious statement is to identify this "someone" (or let him identify himself) and ask him the necessary question(s).
  • »04.08.10 - 15:00
    > yet [...] As long as the MorphOS Team stays silence on this matter...
    What seems to be an official clarification from the MorphOS Team is there at last:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=7289&forum=3
    Thanks Piru!
  • »04.08.10 - 16:44
    Well, now that Piru has cleared that one up I feel relieved.
    Pascal's statement did seem questionable. He'd also made a statement about other things he knew that he couldn't talk about. And his statement seemed to bolster his own position and endeavors.
    Oh, and on the world ending in 2012, it would do us all good to remember that the world may not end during the time our species is on it. However, since the vast majority of species that have existed are now extinct, we may not continue to inhabit it indefinitely.
  • »04.08.10 - 16:53
    Charvel
    Posts: 97 from 2007/2/15
    One day, when the PPCmacs are growing really old and slow, of course they need to make a jump to another CPU-family. And Iḿ pretty sure it will be X86. But now?
    No, Morphos is superfast even on a Peg 1. with a G4 or G5 there is more speed than a MorphOS user will need.
    Only support for newer graphic-cards needed.
  • »04.08.10 - 20:26
    BurnTwice
    Posts: 38 from 2009/10/27
    @ jcmarcos
    True, you have a great variety of components in the PC sector.
    On the other hand, the amount of different chipsets has declined over the years since PCs conquered the marked and a lot of companies were founded. Today, there are few left in comparison.
    But development is fast and therefore time is short to support new components (drivers), especially for small market companies in the Amigaoid sector.
    Even for Apple this seems to be the point, they select hardware for each line of their products, so in model x is always the same hardware which can be supported thoroughly. The product cycles are not so fast like in the Wintel world, the same with consoles etc.
    Quite the strategy like in the good old home computer times :-)
    To put it all into a nutshell, I see no problem to switch to
    specific X86 systems and to support it. And...why not profit again from Apple?s efforts and after their PPC-machines support their well tested X86 machines in the future? ;-)
  • »04.08.10 - 22:24
    I think that idea, to support Intel powered Mac computers if/when the MorphOS Dev. Team makes a switch away from PPC to any other architecture will very likely be met with several loud cries against such a move, from those that do not like Apple products, usually because they do not like the company, or Steve Jobs, but also because the price of Intel Macs is higher than similar hardware used to build a generic PC, or PC's manufactured by other high volume PC manufacture's, such as Dell, HP/Compaq and others.
    I like Apple products, so I would not mind being able to continue dual booting into MorphOS and MacOSX on an Apple computer w/Intel inside, but I fear I am in the minority and most would prefer a cheaper option to build their own x86 MorphOS machines than pay the high prices of new Intel Mac computers, or to have to repeat the process of purchasing used first generation Intel hardware, instead of what ever is current at that time.
    jcmarcos wrote:
    [QUOTE] But development is fast and therefore time is short to support new components (drivers), especially for small market companies in the Amigaoid sector. [/QUOTE]
    I don't quite understand your statement quoted above, as I believe the opposite. I think that due to the small size of the MorphOS Dev. Team, it will take an extended time for the MorphOS Dev. Team to support the latest x86/x64 hardware, compared to the other mainstream OSes, and we will always be using hardware that is some months, or perhaps even years behind the latest and greatest, just released hardware that has Windows, or MacOSX support and to a slightly lesser degree, hardware supported by Linux and other niche x86/x64 OSes that are already established.
    Perhaps I am misunderstanding what you are meaning, or trying to write?
  • »05.08.10 - 06:21
    jcmarcos
    Hey Dave, that quote isn't from me! I don't understand it, either. We should all be very aware of one thing: Compare people's personal taste about a component they actually don't know (the CPU) with the HUGE job of rewriting software for a different one. People's likes simply don't compute.
  • »05.08.10 - 08:22
