Tabor
    Posts: 2511 from 2003/2/24
    1 dumb people in Amiga community think that if they make problems where no problems at all there will be switch to some Linux based brainfart
    As long as AROS x86 or MOS x86 is as on PPC to it will justify setting up separate box for it just like it is/was for PPC.
  • »28.12.19 - 08:25
  • vox
    vox
    Posts: 616 from 2003/11/24
    ppcamiga1 wrote:
    As I explained this in pm on aw earlier I prefer to spend little money to get working hardware and drivers instead of wasting time on pointless attacks on H&A.
    The problem is in way that You vox deal with problems. But it is Your problem.
    No its all x1000 users problem, others just tend to ignore it.
    But Nemo is shelved, is expectations for 2020 are:
    -Dont go Tabor, its cheap but x1000/x5000 debacle, even worse
    - I will go v4SA and enjoy it more then x1000 at cost-effective choice
    - I hope I will buy MOS x64 license for a PeeCee
  • »28.12.19 - 15:21
  • vox
    vox
    Spectre660 wrote:
    It was stated a while ago that X1000 CFE was not under A-Eon's control.
    Don't know if they have made any progress on this.
    Lincese says Broadcom FLOSS + glued by Hyperion.
    I mean, you develop patched firware for routers to work on desktop.
    Then you loose sources after two beta updates and public release.
    Then you start developing onboard driver for ethernet. You outsource it,
    programmers Nemo dies and you put bugged version of OS 4.1FE, never send
    him replacement Nemo (I am willing to, just link me) and you put him to other task.
    That is the way of support of OS4 dream machine.
    [ Edited by vox 28.12.2019 - 18:31 ]
  • »28.12.19 - 15:21
    Posts: 12451 from 2003/5/22
    > Lincese says [...] glued by Hyperion. I mean, you develop
    > patched firware for routers to work on desktop. Then you
    As far as I understand, the issue is that one "you" is a different entity from the other "you". In addition, one of the entities likely never had the source code but just binaries.
    Isn't the buggy driver only available for beta testers?
    > never send him replacement Nemo
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&start=1029
  • »28.12.19 - 20:59
    redrumloa
    Posts: 1424 from 2003/4/13
    rob wrote:
    I've seen a few hints including one from Trevor and if I've not misread the hints then there will certainly be something in Enhancer 2 that is a first for any Amigoid OS.
    And you fell for it hook, line and sinker? After all these decades?
  • »29.12.19 - 02:18
    redrumloa
    rob wrote:
    Hence my not stepping out on the line to express what I think may be being hinted at.
    OK, fair enough.
  • »29.12.19 - 02:20
    ppcamiga1
    Posts: 215 from 2015/8/23
    Kronos wrote:
    usual crap
    Some dumb people in Amiga community expect others in Amiga community to fool themselves that pc with MOS is not pc. "no it is not a pc and I can not do my work hundred times faster on windows on exactly the some computer"
    It is obvious that on x86 AROS or MOS will compete with Windows, macOS and linux.
    Nobody sane will use MOS or AROS when the some work may be done in minuts on win/osx/lnx instead of hours on AROS or MOS.
    MOS x86 in current form end as AROS x86 as worse uae.
  • »29.12.19 - 15:06
    ppcamiga1
    From developer POV V4SA has not working MMU and decent OpenGL so it is still not good enough to compete with Amiga X1000 or Amiga 1222, and of course it is many times slower.
  • »29.12.19 - 15:08
  • vox
    vox
    I dont get the updated info from thread? Anything new or different from what I have rad in past?
    No, it is included on OS 4.1 Final CD
    System/devs/networks/ppp-ethernet.device 23.11.2014. 00:00
    http://amigax1000.blogspot.com/2017/01/amigaos-41-fe-updates-and-repaired-x1000.html
    You are then asked to choose your network card. I got a bit excited when I saw that the built in X1000 network adapter is included as an option (we have to use a PCI network card under AmigaOS4.1.6). I selected the built in adapter and click on Test this Configuration:
    https://2.bp.blogspot.com/-RI3_VFbMB9A/VK0jL9InRnI/AAAAAAAAKhI/blSzV5Iadao/s1600/IMG_6336.JPG
    https://2.bp.blogspot.com/-V6strDS-EAc/VK0jMB5zLRI/AAAAAAAAKhM/jgBVX7_-g-4/s1600/IMG_6337.JPG
    Unfortunately it didn't work - I also subsequently found out the built-in network driver has dropout issues and shouldn't be used by X1000 owners at this time.
    I am no developer. Real OpenGL on my x1000? Where? :) Dont call translation of a translation to some level GLES :) Smaller set we will have as miniGL by Hyperion? :) and StormMESA m68k once Vamp v4 gets a bit more 3D love. Still before OS 4.2 or Libre, I bet. And hardware wise its growing, V4 has space for m68k style MMU and much more.
    From user Vamp:
    - Has proven development on SW and HW FPGA core side
    - Is out of box Amiga compatibile
    - I prefer small bussiness to greedy milkers that lie and smile too often
    - I believe it will bring more AmigaOS related development, OS3+AROS
    [ Edited by vox 30.12.2019 - 09:43 ]
  • »29.12.19 - 19:58
    ppcamiga1
    Yes, as usually, in the far-away future v4 will have decent OpenGL and working MMU.
    Or not, as this whole natami crap prove.
    Amiga ppc has it NOW!!!
    So dear vox don't compare something real with something that exist for now only in gvb imagination.
  • »30.12.19 - 09:32
  • vox
    vox
    Buggy OS, buggy CFE, no aos AND no Linux support is real. Enjoy it.
    Its on sale for price of new Tabor "complete sys" and with a bit less beta OS and drivers
    https://amigaworld.net/modules/classifieds/index.php?pa=viewannonces&lid=6
    Good future to all! Especially Tabor users!
    [ Edited by vox 30.12.2019 - 14:10 ]
  • »30.12.19 - 12:08
    ppcamiga1
    But with decent OpenGL and working gdb.
    So yes it is better than v4.
  • »30.12.19 - 13:07
    In comment #1030 in that thread you acknowledged that he was sent a replacement Nemo while in this thread you now claim he wasn't.
    Indeed, thanks for the reminder.
    Why not? GL4ES offers full OpenGL 2.1.
  • »30.12.19 - 21:38
    Spectre660
    Posts: 276 from 2015/6/30
    A1222 Plus
    [ Edited by Spectre660 31.12.2019 - 09:53 ]
  • »31.12.19 - 12:52
    Spectre660
    Hope you wiped up properly .
    Zylesea wrote:
    Spectre660 schrieb:
    Game changing stuff .Tabor support included .
    Enhancer V2.0 coming soon.
    [ Edited by Spectre660 26.12.2019 - 12:54 ]
    "Game changing" - you made me spitting the coffee over the screen and key board because of LOL.
    Cought in a atime capsule from one or two decades ago--?
    Funny! A classic. More of that, please!
  • »31.12.19 - 22:33
    Posts: 2069 from 2003/6/4
    Well, the floor is pretty clean ;-)
    And indeed hardware accelerated video playback is a nice achievement and pretty handy. But game changing... rather not.
  • »01.01.20 - 12:45
    OlafSch
    Posts: 190 from 2011/11/16
    User do not use any OS because it is "better"
    They use it because of available and (in best case) exclusive software. And developers support a platform not because it is "better" but because of the users (and thus potential buyers). There is the big advantage of vampire (together with UAE)
    [ Editiert durch OlafSch 01.01.2020 - 14:23 ]
  • »01.01.20 - 13:22
    Spectre660
    The video playback is actually more powerful than demonstrated in the video.
    Think up to Ultrawide 1600 res. Under 10% CPU usage for whatever multiple video combinations that work with currently available GPU ram (Sam460ex test machine).
    Eventually being able to offload video decoding,encoding ,3D and 2D Graphics (Skia like) to the GPU would be Game changing for computers using Powerpc processors .
    [ Edited by Spectre660 01.01.2020 - 10:44 ]
  • »01.01.20 - 13:42
    I said it's a nice feature and pretty handy an cpu weak computers, but this is not game changing, It's just catching up in one standard discipline.
    Not bad though, really not.
  • »01.01.20 - 14:45
  • ASiegel
    Posts: 1396 from 2003/2/15
    Personally, assuming mainstream video codecs are in fact supported which Spectre660 has not confirmed, I find it to be a million times more useful than being able to run smartphone games on desktop hardware.
    That said, for better or for worse, media consumption on desktop computers has moved towards web browsers. If a 50 EUR tablet can smoothly play videos on any HTML5-compliant web page but your 1000 EUR desktop computer struggles with 360P and you are expected to use semi-clunky external tools for smooth high-resolution playback that only support one or two video portals, then that would be less "game changing" and more "not even really in the game" territory.
    Of course, as usual, none of this information is provided and people are expected to merely guess and speculate after reading 3,000 word blog posts and watching minutes of video footage.
    If you expect people to invest 700+ EUR on compatible mainboards and graphics cards, being able to play HD video is the bare minimum bar in 2020, I'd say. Not "game changing" but certainly an accomplishment.
    That said, regardless of how smooth the playback might be, I myself could not stand watching videos with messed up color palettes so black looks grey...
  • »01.01.20 - 15:09
    Spectre660
    Simultaneous playback : Sam460ex .Frameskip=Disabled . Videofilter =Yes
    Screenshot
    Video #1
    ID_FILENAME=Media:Videos/Benchmarking_Videos/Top Gun Maverick (2020) - Official Trailer_3840x1600_23.97FPS.mkv
    ID_DEMUXER=lavfpref
    ID_VIDEO_FORMAT=462H
    ID_VIDEO_BITRATE=0
    ID_VIDEO_WIDTH=3840
    ID_VIDEO_HEIGHT=1600
    ID_VIDEO_FPS=23.976
    ID_VIDEO_ASPECT=0.0000
    ID_AUDIO_FORMAT=A4PM
    ID_AUDIO_BITRATE=0
    ID_AUDIO_RATE=48000
    ID_AUDIO_NCH=6
    ID_START_TIME=0.00
    ID_LENGTH=142.55
    ID_SEEKABLE=1
    ID_CHAPTERS=0
    Video #2
    ID_FILENAME=Media:Videos/Benchmarking_Videos/DCS World - 4K Test - UltraWide - 21_9 - 3840 x 1600_29.89FPS.mkv
    ID_DEMUXER=lavfpref
    ID_VIDEO_BITRATE=0
    ID_VIDEO_WIDTH=3840
    ID_VIDEO_FPS=29.900
    ID_AUDIO_BITRATE=0
    ID_AUDIO_RATE=44100
    ID_AUDIO_NCH=2
    ID_START_TIME=0.00
    ID_LENGTH=253.21
    ID_SEEKABLE=1
    ID_CHAPTERS=0
    [ Edited by Spectre660 01.01.2020 - 13:15 ]
  • »01.01.20 - 15:55
    Spectre660
    @ASiegel
    No issue with color palettes here .
  • »01.01.20 - 16:31
    number6
    Posts: 487 from 2008/8/10
    Spectre660 wrote:
    @ASiegel
    Just a thought since you are trying to report what can be achieved here...
    Most people would simply ask if they can play H/D or HiDef in sync and without frameskip using a high stress codec, which would be expected from almost any source these days.
    PPC MPlayer is not getting bugs fixed. In fact the bug report was closed without being addressed for what is showing up in your Video and Audio codecs output.
    It might be helpful to mention that it's not "462H", but "H264" for video codec, and it's not "A4PM" but "MP4A" for audio codec.
    #6
  • »01.01.20 - 17:14
