Help with WHDLOpener
    Posts: 3 from 2025/3/10
    I'm hoping someone can assist me. I've been trying to install WHDLOpener and it keeps failing with "can't download WHDLoad_usr_small.lha". Is it looking for a file on the Internet that is no longer where it expects it to be? Is there a way to edit where it is looking. I have the actual file on the Mac Mini G4 that I'm trying to do the install on. Or am I doing something else wrong? Thanks for any help you can provide.
  • »07.03.26 - 10:04
    Papiosaur
    Posts: 2581 from 2003/4/10
    Maybe your clock is not set and you can't download because that (SSL need clock set)
  • »07.03.26 - 19:28
    Tomtom76
    Posts: 44 from 2021/6/26
    Just download manually "WHDLoad_usr_small.lha" place it in in WHDLoad installer directory. Don't extract it just run installer. You can place all needed components required for installation in the same place if needed.
    Powerbook G4 A1106 MorphOS 3.19 & MacOSX 10.4
  • »07.03.26 - 20:05
    That's got it sorted - thanks for your help 👍😎
  • »08.03.26 - 20:52
    Perfect, worked nicely, Thanks! 👌😎
  • »08.03.26 - 20:54
