Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Beginners
Wayfarer Fonts not downloading
stevereaver
# 1
Just looking around
Posts: 2 from 2025/2/15
As the title says, I just updated to the latest version of Wayfarer and when I start it, it prompts me to update the fonts. The updates starts but they all stay stuck at 0%. Anyone know how to fix that ?
Also, hi, I'm new. Morphos seems awesome.
18.02.25
07:34
Papiosaur
# 2
Posts: 2497 from 2003/4/10
Maybe, you don't have the good day...if you are in 1978, there is a problem to connect to the server.
Ko-fi
Easy2Install
www.meta-morphos.org
www.morphos-storage.net
18.02.25
10:24
MorphOS Developer
Posts: 3264 from 2003/3/5
Please make sure your system time is correct. Https will fail if your date is wrong since ssl certificates all have valid from/until dates.
18.02.25
10:27
