Still cant change ADF icons succefuly
    laios
    Posts: 12 from 2022/11/9
    Hi
    I want to change the icon of ADF files . I downloaded some nice packages choose one with diskettte , drop this in info screen on the top of the other , the one with the saw which is the default , and save . Nothing still the default also info screen doesn't show up any more . Suposse the solution is simple but as beginer ..
    [ Edited by laios 09.11.2022 - 17:43 ]
  • »09.11.22 - 14:38
    Papiosaur
    Posts: 2577 from 2003/4/10
    Hi laios,
    if your ADF has a Amiga filesystem, there is normally a Disk.info into the ADF (in the root). This file is the icon of the disk.
    You can change it copying a new Disk.info different over it.
    If you ADF has no icon, Ambient take a default icon named def_disk.info placed into sys:prefs/presets/deficons/
    You must change it if you want another icon for your ADF.
    [ Edité par Papiosaur 09.11.2022 - 17:26 ]
  • »09.11.22 - 15:10
    laios
    ok thanks , I tried no changing
    [ Edited by laios 09.11.2022 - 18:47 ]
  • »09.11.22 - 15:40
    laios
    Papiosaur wrote:
    Hi laios,
    I found in the Ambient Settings - > Mime the x-adf entry for the adf files I tried there to change the icon association for the ADF . But get the message " Couldn't save "SYS:Prefs/Presets/Deficons/application/x-adf.info" default icon . What I have to do to permit saving ?
  • »09.11.22 - 15:43
    Papiosaur
    Ambient Settings - > Mime is destinated to associated actions (mount, play, show, edit, etc...) to differents file format, not for the icons.
    Maybe you can change the SYS:Prefs/Presets/Deficons/application/x-adf.info icon to another.
    [ Edité par Papiosaur 09.11.2022 - 17:46 ]
  • »09.11.22 - 15:45
    laios
    ok I see whatI can do thanks
    [ Edited by laios 09.11.2022 - 20:02 ]
  • »09.11.22 - 16:07
    laios
    I think the problem is there is no x-adf.icon in the folder
  • »10.11.22 - 02:41
    laios
    Papiosaur wrote:
    You can create it.
    A MorphOS icon is a png image renamed as *.info instead *.png.
    Thanks I made it everything ok
  • »12.11.22 - 18:01
