Morphos 3.15 doesn't boot on my AmigaOne X5000
    Posts: 123 from 2022/7/1
    Brumiga wrote:
    @bearerofthetorch,
    Thank you Bruamiga!!! Your proposition is great nut I am medicated and I have no csr or driving license renewed (mine is form 2004)
    My solution is to format both HDs under Windows/Linux and try to install later AOS%MOS
    Thank you
    I can propose to you a solution. Over the coming weekend, during 3 days, there will be a little gathering, the NASS, at Surgère near La Rochelle, https://www.nass-4a.org/ . Warning, the web site is only in french. Despite this might represent for you 1500 or 2000 km, if you come by road, can or could you come to this gathering ? I also own an amigaone x5000 bought 2 years ago from amedia computer, I use it with morphos but not with amigaos. I maybe could help you to obtain your amigaone x5000 to finally boot on morphos or on amigaos.
    What do you think about my proposition ?
    Brumiga
    [ Edité par Brumiga 05.07.2022 - 10:34 ]
  • »05.07.22 - 14:42
    Brumiga wrote:
    @bearerofthetorch,
    Thank you
    Brumiga
  • »05.07.22 - 14:42
    Brumiga
    Posts: 275 from 2004/4/3
    @bearerofthetorch,
    Have you tried to take off pci-e 16x the graphic card for amigaos 4.x and install the graphic card compatible with morphos you own ? In january, in this thread https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=13268&forum=3#151790 Primax had a problem. His amigaone x5000 that did not boot any longer. His hard drive or solid state disk was in revalidating state. This is because his vendor when he installed morpĥos had left the automatic layout. In this case the partition for morphos is created and formated ffs lnfs dos7 instead of sfs. May be is it your case. Try to boot with morphos copied on a cdr or the image version copied on a usb stick. If you boot successfully verify with hdconfig, present in tools, what is the kind of the system partition.
    Brumiga
  • »07.07.22 - 12:43
    Brumiga wrote:
    @bearerofthetorch,
    Brumiga
    OK nice info.Thank you really with Amigans like you this comunnity advance and grow up.
    Today close to the night,I managed to boot my Morphos USB pendrive.I tried to install 3 or 4 times without success but about more than 10000 files were copied.Don't know really what happens.I also re-partitioned the Morphos HD to stay sure all is right on track.But I musn't see why Morphos musn't install well.
    If you have something to appoint please do it soon.I am stuck on this issue
  • »11.07.22 - 19:40
    bearerofthetorch wrote:
    Brumiga wrote:
    @bearerofthetorch,
    Brumiga
    Ah! Great news!!! Forgot to say that I re-installed succesfully my AmigaOS 4.1 FE Update 2 this last 9-7-2022 Saturday.I am very happy with it,I am using now.
  • »11.07.22 - 19:42
    Posts: 1354 from 2004/2/8
    Strangely enough, one of the new MorphOS users in Poland had similar problem.
    He installed a clean MorphOS 3.17 on AmigaOne X5000 and went testing the Wayfarer browser. Then the "demo timeout" expired and he tried to close Wayfarer window, but it stuck there. After a good while he decided to shut down the system. After that, MorphOS wouldn't start again (hangs on the "butterfly" screen). He booted from a live CD and started a SFSDoctor but it says the partition cannot be fixed.
  • »18.07.22 - 16:24
    Posts: 841 from 2007/10/23
    @koszer
    Maybe a detailed SFS log can help...
  • »19.07.22 - 05:58
