How do I install Wordworth 6 Office?
    Posts: 4 from 2021/8/15
    Hello, I've purchased a licensed copy of Wordworth 6 Office from 1996. However, I can't get the installation to work.
    My setup is:
    PowerBook 6.5
    1200 MHz
    735 MB RAM
    MorphOS 3.15
    After booting up, I open the shell, cd to english_products/wordworth_6, then do:
    execute install_wordworth_6
    After choosing "Expert User" at the installer, then "Install for real", then chosing the destination for the "Wordworth6" folder, it asks: "Do you wish to install the small font library?"
    Whether I click "Yes" or "No", it bails out with the message:
    "Sorry... an Error Has Occured!
    MAKEDIR: Couldn't create directory
    DOS Error Type: Cause of disk-.related error unknown."
    The Wordworth6 folder has been created by the installer, though, but it is empty.
    Logging the installation process to a file doesn't work.
    How can I find out what went wrong and proceed with the installation? Any help would be appreciated.
  • »15.08.21 - 18:26
    Posts: 2094 from 2003/6/4
    It's abit ago that I installed Wordworth, but IIRC it didn't work OOTB. Easiest workaround is to just copy an existing istallation to MorphOS. Set the "PICASSOTRUE" tooltype and it should work.
    Obtaining a working installion: just do it on an UAE setup (most andy probably under MorphOS UAE as yu are on the right machine then from the beginning).
    [ Editiert durch Zylesea 15.08.2021 - 23:45 ]
  • »15.08.21 - 19:40
    NewSense
    Posts: 1618 from 2012/11/9
    @ Farroukh - I seem to remember that the installer on the disc has to be substituted for the MorphOS Installer and it will install correctly, but as Zylesea mentioned, it's a while ago since I installed it, but then I haven't found a real use for it as it has trouble printing PostScript to the new/current MorphOS PPD printer system, and PostScript I always found to be a bit "messy" with WordWorth. I preferred to print via Turboprint (7) on Amiga OS3.9 but that hasn't worked for me, as such, on MorphOS to my recollection, and there's no Printer option to get it to use USBPAR:, only to send a file to USBPAR:, and I'm not sure that works either. :-?
  • »15.08.21 - 21:44
    Thank you so much for your replies. I re-tried the installation procedure with InstallerLG 44.10, and it worked! Datastore and Organiser from the office suite have been installed smoothly and are running perfectly fine. The installation of Wordworth proper required me to comment out a few lines in the install script, near the end of the process, but the program has now also been set up.
  • »17.08.21 - 15:39
    Troubleshooting stuff like this is the only thing that makes me prefer Windows (that and plentiful apps for Windows).
  • »17.08.21 - 15:49
    Hey Jim. since when do you actually *prefer* Windows? I think Windows is the well known necessity we are all used to and have arranged with. But we all prefer MorphOS of course ;-).
    And isn't the fiddling with the system the candy of our boring daily IT life?
  • »18.08.21 - 20:44
    NewSense
    Zylesea wrote: - [... But we all prefer MorphOS of course ;-). And isn't the fiddling with the system the candy of our boring daily IT life?
    Me . . . + 1 . . . to that :-D
  • »20.08.21 - 00:18
    sTix
    Posts: 41 from 2003/12/7
    Glad it works for you. May I ask what lines you needed to comment out?
  • »20.08.21 - 10:14
    Sure, it was lines 2003-2013. I think those were meant to install the printer driver. That didn't work because apparently, the variable containing the driver archive hasn't been set.
  • »21.08.21 - 09:49
    sTix
    Thanks!
  • »22.08.21 - 19:53
    It would be if I could keep a system up and running, my G5 now overheats and I dread rebuilding the coolant system. Truly looking forward to an X64 shift so I can stop using PPCs.
  • »24.08.21 - 12:20
    Posts: 846 from 2007/10/23
    ...or a modern platform like Arm M1.
  • »24.08.21 - 18:04
    Posts: 12556 from 2003/5/22
    …unless announced plans didn't change :-)
  • »24.08.21 - 18:18
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Sure... Without any documentation about the iGPU and other stuff the M1 incorporates... Or how would you convince Apple to release at least hardware specs & documentation of their ARM stuff?
    Nope, not Apple again. Certainly the M1 is very powerful but IMHO it's even more deadend than the PPC-Macs are. They are doing their best to keep their hardware 'secrect' and the Linux OpenSource community is having a hard time to reverse engineer every bit of it...
    A bit of an OT rant, I know. ;-)
  • »25.08.21 - 16:30
