Problems with ED with multiple sessions
    Posts: 158 from 2019/4/6
    Hello everybody,
    I recently approached Morphos
    this is my configuration:
    Powerbook G4 1.67 15 '2gb of ram ati 9700 128mb
    I have installed Morphos + ChrysalisPack + sdk
    I'm probably doing something wrong
    my question is this:
    I launch ED and open a file
    I edit it
    then in the same session I try to open ED again
    to edit another file but nothing happens it does not make me open any folder and I cannot interact with the rest of the system only an hourglass remains (if I close ED everything works again)
    I cannot access the menu to launch another ED session
    Only by opening a shell can I get another ED session
    are there any settings in the GUI to make to allow multiple sessions at the same time?
    Thanks for any suggestions or advice :-)
    [ Edited by white 22.05.2021 - 20:19 ]
  • »22.05.21 - 16:18
    Posts: 2217 from 2003/2/24
    You're launching ED from a pull-down menu? Sounds like it's launched without "Run >NIL:" so it's a configuration error in Chrysalis. I don't have Chrysalis installed, but maybe there's some script file in WBStartup which creates custom menus... check the file and add Run >NIL: in front of ED command line?
  • »22.05.21 - 16:32
    @jPV
    Thanks for your answer.
    i will only install morphos
    because maybe there are other things wrong
    i noticed that a shell opens at startup but it is very fast hard to notice.
    I will build the system little by little :-)
    Thanks again for the answer. :-)
  • »22.05.21 - 17:02
    Yea, I like to build my systems myself to know what's where and how it's done ;)
    Here's something to get started:
    https://library.morph.zone/Getting_Started
    Although it has some outdated information too.. like the latest MPlayer isn't probably found in Grunch...
  • »22.05.21 - 17:08
    @Papiosaur
    Thanks to you.
    It is possible to have a correction of the file
    because I tried to edit the "crabum.rexx" file
    but i can't find the solution.
    This would allow me to continue configuring Morphos and trying it out and continuing to experience all of its applications.
    I would save a lot of time at least initially because I just bought the G4.
    Always if the problem lies in the "crabum.rexx" file and it is easy to fix.
    Thank you
  • »23.05.21 - 07:28
    Papiosaur
    Posts: 2577 from 2003/4/10
    If you have always Chrysalis pack, edit sys:wbstartup/crabum.rexx (contextual menu with right button of the mouse)
    search tittle="ED"
    modify command to "run >NIL: ED %sp"
    Now you can select file(s) then EDIT them via menu.
    The pack is not perfect but i try to improve it with the help of users, thanks to you for your return.
    New version of the pack is uploding...
    [ Edité par Papiosaur 23.05.2021 - 15:29 ]
  • »23.05.21 - 11:04
    @Papiosaur
    To be precise I put a video to explain myself better I hope it will be useful
    here you can see how the whole system crashes (freeze)
    https://www.youtube.com/watch?v=rWU_R9AnrCw
    in this case i used qemu with morphos to make the video easily but that's what happens on real hardware
    Thanks again for your work.
    [ Edited by white 23.05.2021 - 23:42 ]
  • »23.05.21 - 19:33
    @Papiosaur
    As I was suggested to me in a forum
    This seems to solve the problem in Crabum.Rexx
    CommandType=Workbench Command="C:ED"'
    It seems to work and the freeze does not occur
    I can't wait to start using Morphos with Chrysalis-Pack will help me a lot to discover the system and all your potential.
    Thanks again for creating it.
    [ Edited by white 24.05.2021 - 09:46 ]
  • »24.05.21 - 03:55
    @Papiosaur
    currently with the new ED update it does not work directly from the taskbar menu
    adding:
    Workbench C:ED
    everything works without any locks and works using it from the taskbar menu
  • »24.05.21 - 05:49
    white wrote:
    @Papiosaur
    BTW. nothing actually "crashes" there, it's just that if you launch a program from the Ambient pull-down menus without launching it as a background process, it blocks further operation of Ambient until the program has been quitted.
    So, when you launch a program that doesn't start as a background process itself, it's important to remember to launch it as a Workbench program or with the "Run >NIL:" if launched as a command line program.
    This has also been mentioned here: https://library.morph.zone/Getting_Started#Creating_Menus_with_CRABUM
  • »25.05.21 - 05:09
