Choppy Sound on PowerMac Dual G5 with E-UAE
    Storm
    Posts: 6 from 2018/4/6
    Hi all,
    I have two MorphOS systems, a G4 Mini where everything works perfectly well including E-UAE, and a PowerMac Dual G5 2.3GHz.
    I am having a problem on the G5 where the sound in E-UAE sounds a bit choppy and broken up. I have tried a few different E-UAE versions with no success.
    I'm sure I didn't have this issue on my Dual 1.8GHz G5 when it was in service (which is now dead due to a faulty logicboard and the 2.3Ghz has replaced that).
    Has anyone else had this problem or know how to solve this?
    Thanks in advance.
    Running MorphOS on a Power Mac Dual G5 and a Mac Mini G4.
  • »12.11.18 - 03:03
    Storm
    I must be the only one with this issue :(
  • »16.11.18 - 03:54
    redrumloa
    Posts: 1424 from 2003/4/13
    I haven't used eUAE in a while, since I have a real Amiga again also. Are you using JIT eUAE? If so, are you using the G5 specific executable?
  • »16.11.18 - 16:31
    Posts: 897 from 2003/3/4
    I know at least one other person who owns a G4 powerbook who also has it.
  • »16.11.18 - 20:02
    Storm
    Yes it's a strange one. I have tried a lot of differing versions of E-UAE, JIT, normal, G5 specific, and they all do the same thing. I thought it may have been my machine, but every other sound on the system is fine. I have tried to fine tune the settings in E-UAE, with no improvement.
    Lucky, I do have some real Amigas setup.
  • »16.11.18 - 22:23
