Where can I set the time server IP ??
    Barren
    Posts: 39 from 2016/12/29
    Today they switched to DST here, but when I turned on MOS I saw the wrong time set (still winter time).
    My Time zone is correctly set in system prefs (Rome etc). My router (acting as Time Server) has proper time set.
    But where does MOS get its time data ??
    I have enabled in S:user-network-startup SetClockNTP SAVE but... where can I enter the time server IP ?
    I searched thru the system network prefs, time prefs... I could not find a place where I can set it.
    Because I'm sure MOS is NOT making reference to my default gateway to get the correct time, but to somewhere else.
    So ?
    Thanks in advance
  • »26.03.17 - 09:34
    Korni
    Posts: 473 from 2006/2/23
    "SetClockNTP ?" will give you all the options, including SERVER, but switching the server will not help. I use a simple script to manually switch between CET/CEST. Of course you need to adjust UTCDIFF to your timezone. WaitX part is needed only if you want to update your time each hour etc.
    S:User-Network-Startup
    Run >NIL: SetClockNTP UTCDIFF=120 SAVE
    S:Time_CET
    bin:sed -i "s/SetClockNTP UTCDIFF=120 SAVE/SetClockNTP UTCDIFF=60 SAVE/" S:User-Network-Startup
    Break `Status COM WaitX`
    Run >NIL: WaitX H=1 L=0 "SetClockNTP UTCDIFF=60 SAVE"
    S:Time_CET
    bin:sed -i "s/SetClockNTP UTCDIFF=60 SAVE/SetClockNTP UTCDIFF=120 SAVE/" S:User-Network-Startup
    Run >NIL: WaitX H=1 L=0 "SetClockNTP UTCDIFF=120 SAVE"
  • »26.03.17 - 10:11
    Barren
    Oh u are using commands from the SDK I see LOL
    Ok thanks that was useful
    I hope automatic DST support will be included in some future MOS releases though, if possible.
  • »26.03.17 - 12:44
    Posts: 847 from 2007/10/23
    Why so complicated?
    setclockntp uses always DST without the NODST option, right?
    north-america.pool.ntp.org:123 europe.pool.ntp.org:123 pool.ntp.org:123
    [ Editiert durch polluks 26.03.2017 - 19:00 ]
  • »26.03.17 - 14:44
    Posts: 2220 from 2003/2/24
    polluks wrote:
    Why so complicated?
    Yes, and if it doesn't work for some area, user should make a bug report and it'll be fixed (happened for Finland, for example, and it's fixed now).
  • »26.03.17 - 16:59
    Korni
    I don't want to edit my network-user-startup by hand if not needed. It works for me. When MorphOS will have automatic time adjust then I will get rid of it :).
  • »27.03.17 - 04:20
    Posts: 1096 from 2004/9/23
    The main problem is that time settings are more complicated than it looks.
    Many countries do not have fixed time switch times. They use a dice each year and you need to update some database over and over to keep track of that.
    MorphOS´ SetClockNTP just uses countries with predicable switch times.
    The most important thing is to setup the time zone settings in locale correctly or it will fail.
    Second the network-user-startup is exactly designed for this, so just remove the colon in there and you have proper time settings as far as it goes with the limitations mentioned above.
    About the servers used. There are some servers build in, so SetClockNTP will switch when some network (each of these servers is usually redirected to a random time server), so you don´t need to change the server at all. The server has nothing to do with the DST or the location. Result will always be the same date time.
    [ Edited by geit 27.03.2017 - 09:48 ]
  • »27.03.17 - 05:42
    CISC
    Posts: 619 from 2005/8/27
    IMPO we should all have gotten rid of this DST nonsense years ago... :P
    - CISC
  • »27.03.17 - 06:08
