Posts: 1619 from 2012/11/9
I get a partially open window, (compact window) sometimes after my system has locked up/frozen. Usually that will not re-occur if you open another device, like another partition or folder within that partition, and then close it, and then warm reboot.
Try that, and let us know the result.
I am not sure this should happen anyway, but it does, if it's the same problem that I occasionally have when I get a system lockup/freeze.
