AmiNetRadio woes...
    Posts: 147 from 2013/8/25
    Hi all,
    Trying to get AmiNetRadio to run, but not quite there yet.
    First hit a missing MCC class error, but was able to find the missing file online and have copied it to SYS:class/mui/ and that fixed it.
    Now though, trying to launch gives me a brief red title bar and nothing.
    Snoopium gives the following log lines:
    Action Target Name
    ToolType URL
    ToolType DECODEPRI
    ToolType PRI
    ToolType NOSTARTWINDOW
    What am I doing wrong?
  • »19.09.15 - 14:19
    Posts: 1099 from 2004/9/23
    Use Mplayer. Plays all formats, supports playlists and has a nice GUI.
    When it just comes to mp3 or flac use Jukebox, which comes with MorphOS.
    For Flac you probably need to install some beta flac decoder for reggae.
    Installing AminetRadio is bringing lots of old crappy stuff to your system like E libraries AFAIR. I would avoid that.
    Time to get rid of old stuff from the past.
    [ Edited by geit 19.09.2015 - 17:50 ]
  • »19.09.15 - 14:49
    Thank you for the advice. MPlayer working well with my FLAC files.
  • »20.09.15 - 16:51
    amiga4001
    Posts: 454 from 2006/11/16
    Always using Aminetradio for playing internetradio.
    Just tried Mplayer for the same task..works ok but needs long time for buffering.
    And I can't seem to find a database/list off my netradio's?
  • »21.09.15 - 18:10
    Posts: 2220 from 2003/2/24
    Did you try to change its caching settings? You can see them even in the prefs in GUI.
  • »22.09.15 - 03:14
    Yasu
    Posts: 1724 from 2012/3/22
    Does Jukebox support FLAC?
    My MorphOS blog
  • »22.09.15 - 05:23
    Jeckel
    Posts: 133 from 2007/3/11
    I fully agree, but the problem is that there is no equivalent to AmiNetRadio for some stuff (like mod/chiptune players). And even for mp3/ogg streaming it is much more efficient than MPlayer.
  • »22.09.15 - 06:34
    Yes in some degree. There is an experimental FLAC decoder which allows you to play FLACs in Jukebox, but it doesn't support seeking or tags etc. Better decoder would be nice, but this will do for basic listening too:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9289&forum=32
    And if you want to integrate it better to Ambient, check my signature...
    [ Edited by jPV 22.09.2015 - 11:30 ]
  • »22.09.15 - 07:25
    Posts: 903 from 2003/3/4
    Apparently you don't understand the irony behind that comment. Starting with MPlayer - it's fifteen years old and feels pretty old, at least what's left of it. I still remember the days when it wasn't just a command line viewer for ffmpeg for people without the RAM to use a proper player.
    Let's not even go into that you're running it on a 12 year old OS designed for binary compatibility for an OS from 1991, on hardware that is probably more than six years old...
  • »23.09.15 - 17:30
    pan1k
    Posts: 147 from 2009/1/20
    I use AmiNetRadio most of the time on MorphOS. It runs pretty good too. Mplayer is good for dvd-rips playback.
    MacMini 1.5Ghz / Amiga 4000T Cyberstorm 060, 132MB RAM, Cybervision 64/3D, XSurf-III, MP3@64, Buddha Flash / Amiga 1200 GVP 030, Subway USB, 32MB RAM
  • »24.09.15 - 02:04
