Scribble Freezes!?
    D4Ni3L3
    Posts: 26 from 2013/12/12
    Hello!
    I have on Mac Mini a fresh installation of MorphOs 3.8 and I installed MorphOS 3.5 SDK (20140508). Of course I do have a registered version of the OS.
    It happens that I get stuck every time I open the Scriblle text editor to edit a file ( i.e. little c source file ) because the Scribble freezes and the Mac Mini too.
    I was thinking about installing some older version of the OS and of the SDK to figure out if it works.
    Do you have any idea of why the Scribble is freezing on my machine?
  • »03.06.15 - 05:44
    Nadir
    Posts: 178 from 2003/3/17
    It is hard to know what is going on but it definitely should work on 3.8 (I use that myself of course). You could try to delete the Scribble settings from env:mui/ just in case...
    But I really need a logfile to see what goes on.
  • »03.06.15 - 06:15
    D4Ni3L3
    Can you tell me please how I can have a log text file?
  • »03.06.15 - 06:48
    Nadir
    Either with the Logtool application (which comes with the SDK as far as I remember) or the corresponding screenbar plugin. ramdebug option should be ok to capture a log in your case
  • »03.06.15 - 06:58
    D4Ni3L3
    Thanks Nadir,
    as soon as I come home this evening I would give a look to any log file and let you know...
  • »03.06.15 - 10:32
    Posts: 841 from 2007/10/23
    Probably it's the annoying Scribble font bug...
    just delete ENVARC:sys/font.conf and reboot.
  • »03.06.15 - 11:40
    D4Ni3L3
    Hello Pollucks,
    I have deleted ENVARC:sys/font.conf ,rebooted and now Scribble seems to work but I have lost my Prefs settings...
  • »04.06.15 - 19:36
    D4Ni3L3 schrieb:
    ...but I have lost my Prefs settings...
    I know, use a max. font size of 16.
  • »05.06.15 - 08:12
    Nadir
    Unfortunately I have never been able to reproduce this problem so it is hard to nail it down. However, it is unlikely to be a Scribble issue per se, but more likely some layout issue in MUI or so.
  • »05.06.15 - 08:34
  • ASiegel
    Posts: 1396 from 2003/2/15
    The next time someone experiences this problem, perhaps it might be helpful if they could share their prefs file.
  • »05.06.15 - 09:28
    Posts: 2215 from 2003/2/24
    If someone says "delete something", don't delete it. Just rename it or move it to some backup location for later use/investigation. You still might find it from .recycled directory...
  • »05.06.15 - 15:26
    This is my bad font.conf:
    Type=1 FontName="Psamathe.font" FontYSize=18 FontStyle=0x0 FontFlags=0x0
    Type=2 FontName="Verdana.font" FontYSize=24 FontStyle=0x0 FontFlags=0x0
  • »06.06.15 - 11:07
    deka
    Posts: 136 from 2013/2/12
    I experience also scribble freezing, but seems that I could reproduce it:
    If I open the templates list and insert a template and then close the list, MOS freezes down. If I edit the file before closing the list, it work well further.
    Wasn't played too much with this... maybe the template is bad somehow. (I created the lots of templates)
  • »09.06.15 - 06:01
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    I haven't such problem.
    I can load templates, close the list many many times.
  • »11.06.15 - 19:45
