cpu temp ?
    Posts: 6 from 2015/2/20
    Hello,
    which tool i can use to display the current cpu temperature ??
  • »02.03.15 - 20:17
    Yasu
    Posts: 1724 from 2012/3/22
    Go to the top right. Right click on the square. Choose Modules --> Thermal.
    There are also all kinda of useful tools in Modules :-)
    [ Edited by Yasu 02.03.2015 - 23:29 ]
    My MorphOS blog
  • »02.03.15 - 20:28
    Thank you.
  • »02.03.15 - 20:59
    I am a bit confused.
    I have a apple g5 2.7ghz dual core.
    So first cpu: 81 c
    second cpu: 57 c
    Can that be ????
  • »02.03.15 - 21:06
    Yasu
    Yes, because MorphOS only use one core. The other should be idle and thus, less hot.
    Btw, we have the same computer ;-)
    [ Edited by Yasu 03.03.2015 - 00:23 ]
    My MorphOS blog
  • »02.03.15 - 21:22
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Well, mine show -0.9C :P. Got to be cold down there on my G4 lol
  • »04.03.15 - 08:08
    Posts: 1372 from 2010/1/6
    Very interessting! On my G5 2.3GHz both CPUs show nearly the same temperature all the time (~74°C)......
    Doesn't MorphOS deaktivate one CPU complete?
  • »04.03.15 - 09:17
    Cego
    Posts: 738 from 2006/5/27
    @AmigaHarry
    you can disable the second CPU in Open Firmware. But deactivating it will also result in OS X running just on one CPU.
  • »04.03.15 - 09:27
    Yasu
    How do you deactivate it? Is it recommended?
    My MorphOS blog
  • »04.03.15 - 10:42
    Posts: 839 from 2007/10/23
    see https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9353&forum=11
    of course you can activate it for OSX again
  • »04.03.15 - 13:13
    So in conclusion i can have a bad lcs ???
  • »04.03.15 - 18:02
    Cego
    i was wondering if it is possible to deactivate one cpu and make OS X activate the second one temporarily everytime it boots up.
  • »17.05.15 - 15:10
