ExecIO WSHELL and Morph OS
    osco
    Posts: 680 from 2009/10/20
    ExecIO is a utility that allows the output from operating system commands
    like 'list' to be transferred directly into the variable environment of an
    ARexx script. I have output from the "search" to be parsed into a stem variable.
    Have any used WSHELL in Morphos or does Morph have its own utility? ;-)
  • »06.08.11 - 03:36
    Posts: 848 from 2007/10/23
    The good old VM/CMS EXECIO, pure REXX magic! 8-)
    Well, with MorphOS I have used the clip:
    if rc=0 then address command rxset clip "`"getenv CC65_INC"`"
    if getclip(clip)~="" then open getclip(clip)"/"filename
  • »08.08.11 - 15:06
