Python-2.4.2 release + Pygame port
    Yomgui
    Posts: 348 from 2004/8/31
    Two news in one (but very short):
    1) I've updated my port of Python-2.4 into 2.4.2.
    No changes for the port himself except that I use MorphUP now:
    http://yellowblue.nerim.net/mu/my_softwares.pmi
    2) An excellent news: I've made a special version of Python-2.4.2 with included a port of Pygame (as a static module). It's a very fast port (in 2 days), so no time to make tests and debug (sound may crash your system).
    No MorphUP packages too. And it's overwrite any Python-2.4.2 installation (but has same features + pygame).
    Download it here: http://yellowblue.nerim.net/files/python-2.4.2-mos_pygame.lha
    Pygame permits to write in Python every thing that can be done with the SDL library.
    MorphOSement votre,
    Yomgui
    [edit]
    The version of python with pygame has been compiled with the SDK of latest PowerSDL (11.6)
    [ Edited by Yomgui on 2006/3/7 11:57 ]
    [ Edited by Yomgui on 2006/3/7 15:44 ]
    And now... next project!
  • »07.03.06 - 09:53
    Yomgui
    If anyone 've some repports, good examples, etc..
    let me know ;-)
  • »07.03.06 - 15:01
    todi
    Posts: 140 from 2003/2/18
    Is it just me or does the morphup package not work?
    ToDi
    amigazeux.org
  • »14.03.06 - 19:00
    Posts: 1926 from 2003/10/19
    I had trouble with it myself. Where did you tell it to install? I figured SYS: or libs:
  • »15.03.06 - 02:48
    Yomgui
    Some files are installed in C:, the python.library and all python2.4.2/xxx scripts are installed in LIBS:.
    Then the developper's files are installed where you have choosen for Development/Languages.
    Inportant note: if you've already installed python2.4 before, the library is overwriten, but old python2.4 is not deleted. Evenmore, you should replace the old C:python symbolic link by a new one, pointing on C:python-2.4.2 binary.
    I don't know if MU supports symbolic link.
    Regards,
    Guillaumne
  • »15.03.06 - 08:37
    naTmeg
    Posts: 135 from 2004/2/8
    @Yomgui:
    Your .pmi is too old for the current MU-version, it will not install, nor download your stuff. Please open the index with the generator, select "Index/Update all contents" from context-menu and "Save".
    Thanks
  • »15.03.06 - 10:27
    Yomgui
    naTmeg wrote:
    @Yomgui:
    Thanks
    What!? again!!! eh! NaTmeg, don't update MU too often ! :-D
  • »15.03.06 - 15:47
    Henes
    Posts: 507 from 2003/6/14
    Or make it backward compatible with old pmi.
  • »15.03.06 - 15:51
    naTmeg
    @Yomgui/Henes:
    It is backward-compatible, since now, since 1.0
    I don't change the layout again...
  • »15.03.06 - 17:33
  • pOS
    pOS
    Posts: 217 from 2003/11/14
    I visited pygame.org, but none of the games I downloaded worked.
    Could you give me a link to at least one game that is known to work with this port ? I'd really like and give it a try...
  • »15.03.06 - 19:02
    Yomgui
    @pOS:
    Sometime they can work, but you need to do some modifications by hand in some .py scripts.
    Example: I don't know why, but I've seen that some game s install their .py files in LIBS:python2.4 and not in LIBS:python2.4.2. So when python is launched it doesn't find them.
    Sometime the setup.py script can't work because it uses some hard-coded path like /usr/share/foo to install their data.
    Like in C and others languages, most of programmers are lazy. :-(
  • »16.03.06 - 07:50
    So is a new pmi ready? I am looking to install the new version still
  • »01.04.06 - 22:49
