TinyGL: FBO, Shaders and futur improvements
    bigfoot
    Posts: 508 from 2003/4/11
    Papiosaur wrote:
    [EDIT] Small glitchs in Shader test example here after update and reset.
    Can you show an example of that?
    Papiosaur wrote:
    Seems Textures and Lights for ShaderBoy are not supported on R500 ?
    They are. R500 is now on feature parity with R300, so anything that works on R300 should also work on R500.
    Textures and lighting in ShaderBoy only have an effect if the shader actually utilises them. Try the "vertex lighting" example for the lights (or light 0 specifically in that case) and the "texture" example to test textures.
  • »19.10.22 - 14:52
    Papiosaur
    Posts: 2053 from 2003/4/10
    Exellent!!!
    Thanks a lot bigfoot for this bug fix!
    No more glitchs in beplayer and some games here :-D
    [ Edité par Papiosaur 19.10.2022 - 14:07 ]
  • »19.10.22 - 12:48
    bigfoot
    The fifth public TinyGL beta release is now out.
    This is just a bug fix release that mainly addresses rendering glitches on R500-based Radeons as well as stability issues when running ShaderBoy.
  • »19.10.22 - 10:58
  • MDW
    MDW
    Posts: 455 from 2003/7/26
    koszer wrote:
    I believe this is a bug that was found also in MDW's latest demo. From what I know it's been already fixed by Bigfoot and the fix should be available in a few weeks.
    The bug wasn't reproducible on my PowerBookG4. Recedent was testing the demo on his PowerMac G5 with X1950 and noticed the problem. I only forwarded description of the problem and the demo to Bigfoot. He found reason of the problem and fixed it 4 hours after the report. On Saturday! :) I think we couldn't find other operating system with better support. :)
  • »10.10.22 - 20:28
    Posts: 1241 from 2010/1/6
    Hmm - tested it after reboot and it runs! No more crashes (G5, PB G4) ??!?
    Cannot replicate crash at moment........
  • »10.10.22 - 19:23
    analogkid
    Posts: 659 from 2004/11/3
    bigfoot schrieb:
    Thank you, good to know! And just to be clear, it's only the twister preset that causes a crash, right? Is it a consistent crash, does it happen any time you select it?
    Yes, only the Twister preset causes the crash. But it doesn't crash every time, on both machines. It crashed the first time I started it on each machine, next time it runs. But it could happen that it crashes again if I quit Shaderboy and start it again.
  • »10.10.22 - 19:01
    Can confirm behaviour as analogkid wrote! Crashes allways when selecting Twister.
  • »10.10.22 - 19:00
    ernsteiswuerfel
    Posts: 545 from 2015/6/18
    @koszer, bigfoot: Thanks, good to know! So as always I'll be eager to try out the new Beta. ;-)
  • »10.10.22 - 15:13
    bigfoot
    analogkid wrote:
    @bigfoot: This happens on my two MorphOS systems, too. Powermac G5 (Powermac7.3) with original Mac Radeon 9600 and Powerbook G4 (Powerbook5,6) with onboard Radeon 9600.
  • »10.10.22 - 09:44
    bigfoot
    ernsteiswuerfel wrote:
    Besides I noticed there are some glitches gone in VirtualGP 2 which I had before on this card (didn't have these glitches on my PowerBook G4). But I think it got an additional glitch at some time with the TinyGL beta versions: The sky is often flickering with little squares (about 5x5mm) shining through.
    If of interest I could have a look whether I get this on vanilla MorphOS 3.17 or older versions.
    As Koszer wrote, this sounds a lot like a problem I fixed this weekend. I'll try to get a small bugfix update out this week that will include a fix for that.
  • »10.10.22 - 09:43
    Posts: 1246 from 2004/2/8
  • »10.10.22 - 08:03
    ernsteiswuerfel
    Examples and Shaderboy work fine on my G5 ant its' current Radeon X1300, no crashes so far. :-) Without having the knowledge to do more testing with Shaderboy...
  • »09.10.22 - 22:37
    analogkid
  • »09.10.22 - 21:45
    bigfoot
    Cool_amigaN wrote:
    Thanks Mark!
    Could be my flashed RadeonXT 9800 256MB AGP but on ShaderBoy when choosing Preset: Twister, my system freezes. Can somebody else pls test it as well?
    Well, as per usual, reflashed Radeons are not supported, and since it seems to work for just about everyone else, it being a reflashed Radeon is probably related.
    If you can manage to grab a log somehow, then I can check if there's anything obvious in there. If not, there's probably not too much I can do, as I don't have access to such a Radeon myself.
  • »09.10.22 - 09:58
    Tcheko
    Posts: 512 from 2003/2/25
    Cool_amigaN wrote:
    Thanks Mark!
    This preset is working ok here (Powerbook 17" 1.67). Your system is probably still running (try pinging the machine from another computer for example). The problem is probably located inside r300.library which is the radeon driver for tinygl. If something bad is happening here, the whole graphic stack is frozen (ie: no more rendering to screen). The only solution to grab information of what's going on is to use firewire ochi_mon to catch the debuglog.
    Can you get this firewire debuglog? Without it, it will be hard to figure out what's going on.
  • »08.10.22 - 10:27
    Cool_amigaN
    Posts: 750 from 2011/11/30
    Thanks Mark!
  • »07.10.22 - 23:03
    eastone
    Posts: 44 from 2007/8/4
    Big Thanks @bigfoot !!!!
    All examples are working well on my G4 with Radeon 9650 and G5 with Radeon x1900GT :)
  • »06.10.22 - 19:54
    Posts: 889 from 2004/1/24
    Teh nice :-D
  • »05.10.22 - 16:48
    Papiosaur
    Work fine on my Quad G5 + X1950 !
    Thanks a lot bigfoot !
    [EDIT] Bizarre, i have a small black square in the middle of the window in Doom3 game...
    [EDIT2] Fixed with new SDL2 libraries :-) Thanks a lot beworld !
    [ Edité par Papiosaur 05.10.2022 - 16:39 ]
  • »05.10.22 - 13:54
    bigfoot
    It's time for a new public update of TinyGL. You can download it here.
    The highlights of this update are:
    - Support for shaders on R500.
    - Various shader related bug fixes and optimisations.
    - Inclusion of ShaderBoy to test and play around with shaders.
    See the included readme file for a full list of changes since the last update.
  • »05.10.22 - 09:44
    Papiosaur
    bigfoot a écrit :
    Papiosaur wrote:
    @bigfoot: why Cube Map example up my G5 (X1950) to 100% please ? Bizarre no ?
    It's unfortunately completely normal currently. There is a fix for this in the works, but it needs more testing to make sure it doesn't break anything for anyone, so it'll probably only get fixed with the MorphOS 3.18 release.
    Ok thanks for your return!
  • »12.09.22 - 15:59
    bigfoot
  • »12.09.22 - 14:32
    bigfoot
    MDW wrote:
    Thank you for backward compatibility. :) Currently this is very important for me.
    Of course! If these updates (or any MorphOS update) breaks anything that used to work before, then it's a bug. In that case, please report it to me (or use MorphOS' built-in bug report tool) so it can get fixed as soon as possible!
  • »12.09.22 - 14:30
    kas1e
    Posts: 97 from 2005/10/31
    @Tolkie,waldiamiga
    What program have you in mind to port to MorphOS?
    IrrlichtEngine surely at first (this one can works with very minimal shaders support or even without at all, just need to be opengl 2.x at least), foobillardplusplus also very possible. Things which use lots of shaders probably will be no go for current supported gfx cards: for example Words game quite heavy in terms of shaders support, Eldritch also do use some heavy shaders.. But of course, all depends on the level of GLSL support and the latest/better gfx card which will be supported on Morphos. Even old GLSL shaders of 110-120 version usually big enough with all those things which Tcheko descibe above, which if emulated, will made things with shader be slower than without.
    For now for example i works on some port for os4 based on irrliht engine, which use just one single shader, this one: https://github.com/elnormous/RealisticWaterSceneNode
    See there in directory shaders 2 glsl shaders, which while not big enough by code, still when i use them as it in the game, it drop the FPS in whole game play radically, even if it works and renders as expected. So i tried to optimize it as much as possible => by all this i mean, that even if shader works, it's to be seen how fast and good it is, as it can make things even worse if it written bad in compare with no shader usage at all. And it's quite common that things with shaders can be even slower (and on Windows/Linux that the same), than without. And if many things in shader will be emulated in software, then imagine how slow it will be and better go "no shaders" way.
    In other words once bigfoot and co done, this will be very interesting to play with
  • »09.09.22 - 06:05
