TinyGL: FBO, Shaders and futur improvements
    Posts: 2564 from 2003/2/24
    These drivers are not needed for booting, so anything that is listed for 2D in the 3.18 FAQ will work.
  • »01.07.24 - 01:15
    Posts: 53 from 2018/6/9
    So, the reason I asked the question is because the card in question (HD8490) is listed in this thread (previous page), but isn't listed at all on the Morph 3.18 hardware FAQ page. I don't think it really matters TBH. When I looked up the hardware it seems that an 8490 isn't really much better than the HD5450 that I do have. Unfortunately that one refuses to work in the 2nd slot.
  • »01.07.24 - 17:04
    https://www.morphos-team.net/hardware
    AMD Radeon HD3830, HD3850, HD3870
    AMD Radeon HD4350, HD4550, HD4570
    AMD Radeon HD4670
    AMD Radeon HD4750, HD4770
    AMD Radeon HD4810, HD4830, HD4850, HD4870
    AMD Radeon HD4860, HD4890
    ATI Rage128 Pro
    With 2D graphics acceleration, no overlay:
    AMD Radeon HD5450, HD6350, HD7350, HD8350, R5 210
    AMD Radeon HD5550, HD5570, HD5610, HD5670, FirePro 3D V3800, FirePro 3D V4800
    AMD Radeon HD5750, HD5770, HD6750, HD6770
    AMD Radeon HD5830, HD5850, HD5870, HD5870 Eyefinity Edition
    AMD Radeon HD6450, HD7450, HD7470, HD8450, HD8470, HD8490, R5 220, R5 230, R5 235, R5 235X
    AMD Radeon HD6570, HD6670, HD7510, HD7570, HD7670
    AMD Radeon HD6790, HD6850, HD6870
    So it is listed and it should give you a basic working system on a clean 3.18 install.
    But sure it was an entry level card released 11 years ago, so I wouldn't ecpect much.
  • »01.07.24 - 17:42
    Sorry, don't know how I missed that. I did look, honest!
  • »01.07.24 - 19:58
    bigfoot
    Posts: 510 from 2003/4/11
    Today I've released the tenth public TinyGL beta release.
    The main focus of this release is implementing support for framebuffer objects. However, in the course of doing that, many other related and unrelated parts of TinyGL have been improved as well, resulting in better OpenGL compliance and more features being implemented.
    Please note that the R600 driver is absent from this release, but that it will be readded in a future release once I've updated it to the current TinyGL requirements.
    For software developers, please make sure you read the included ReadMe file for important information on using new TinyGL features and fixes.
    I'd like to thank everyone who's helped test this release, but especially beworld for his tireless testing and feedback regarding framebuffer objects and my general TinyGL improvements as well as jPV for his very helpful testing in this last week that helped me fix a handful of problems that would otherwise have made it into this release undetected.
  • »29.09.24 - 02:48
  • ASiegel
    Posts: 1397 from 2003/2/15
    Yay!
  • »29.09.24 - 03:14
    tolkien
    Posts: 578 from 2013/5/29
    Thanks so much bigfoot, beworld and jpv! Will try right now.
  • »29.09.24 - 08:10
    waldiamiga
    Posts: 96 from 2007/7/25
    Wow! Good news!
    MorphOS.pl
    Alienware 15 R3|WinUAE 5.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 9.x.x
  • »29.09.24 - 09:54
    MoerBoer
    Posts: 239 from 2019/10/15
    Great news, thanks bigfoot, beworld and jPV!
  • »29.09.24 - 12:56
    Brumiga
    Posts: 275 from 2004/4/3
    At every boot I have the activity indicator of debug 'on'. I do not know what/who is responsible, sdl 2 or tinygl latest releases. So here is the log that I obtain.
    20.070| 128 bytes read
    20.070| block#0 bytesum 0x0
    20.070| 0x00: 00 ff ff ff ff ff ff 00 26 cd 11 66 26 0b 00 00 .ÿÿÿÿÿÿ..Í.f....
    20.070| 0x10: 10 19 01 03 80 3c 22 78 2a 2f a5 a5 54 50 9e 27 .......x....TP..
    20.070| 0x20: 10 50 54 33 08 00 71 00 81 40 81 80 a9 40 b3 00 .PT3..q.........
    20.070| 0x30: 95 00 d1 c0 01 01 02 3a 80 18 71 38 2d 40 58 2c ..ÑÀ......q8..X.
    20.071| 0x40: 45 00 56 50 21 00 00 1e 00 00 00 ff 00 31 31 32 E.VP.......ÿ.112
    20.071| 0x50: 38 31 35 31 36 30 32 38 35 34 00 00 00 fd 00 37 8151602854...ý.7
    20.071| 0x60: 4c 1e 53 11 00 0a 20 20 20 20 20 20 00 00 00 fc L.S............ü
    20.071| 0x70: 00 50 4c 58 32 37 38 33 48 0a 20 20 20 20 00 61 .PLX2783H......a
    20.071|
    20.071| ID manufacturer Name = 'IVM'
    20.071| ProductCode = 0x6611
    20.071| Serial Number 260b0000
    20.071| Week of Manufacture 16
    20.071| Year of Manufacture 2015
    20.071| EDID Structure Version 1.3
    20.071|
    20.071| Basic Display Parameters and Features
    20.071| checkDDCdata: Video input: Digital signal
    20.071| Max. Horizontal Image Size 60 cm
    20.071| Max. Vertical Image Size 34 cm
    20.071| Display Transfer Characteristic (Gamma): 2.2
    20.071|
    20.071| Feature Support (0x2a)
    20.071| Supports Active Off/Very Low Power
    20.071| RGB color display
    20.071| Preferred timing mode is indicated in the first detailed timing block
    20.071| (Note: Use of preferred timing mode is required by EDID structure version 1.3 and higher
    20.071|
    20.071| Phosphor or filter chromacity
    20.071| red_x 0.6445 red_y 0.3301
    20.071| green_x 0.3154 green_y 0.6201
    20.071| blue_x 0.1543 blue_y 0.06445
    20.071| white_x 0.2354 white_y 0.1338
    20.071|
    20.071| Established Timings
    20.072| 640 x 480 @ 60Hz (IBM, VGA)
    20.072| 640 x 480 @ 67Hz (Apple, MacII)
    20.072| 800 x 600 @ 56Hz (VESA)
    20.072| 800 x 600 @ 60Hz (VESA)
    20.072| 1024 x 768 @ 60Hz (VESA)
    20.072|
    20.072| Standard timing identification #1
    20.072| code 0x7100 (HActive 1152 Pixels VActive 720 Lines RefreshRate 60Hz Aspect 16:10)
    20.072| Standard timing identification #2
    20.072| code 0x8140 (HActive 1280 Pixels VActive 960 Lines RefreshRate 60Hz Aspect 4:3)
    20.072| Standard timing identification #3
    20.072| code 0x8180 (HActive 1280 Pixels VActive 1024 Lines RefreshRate 60Hz Aspect 5:4)
    20.072| Standard timing identification #4
    20.072| code 0xa940 (HActive 1600 Pixels VActive 1200 Lines RefreshRate 60Hz Aspect 4:3)
    20.072| Standard timing identification #5
    20.072| code 0xb300 (HActive 1680 Pixels VActive 1050 Lines RefreshRate 60Hz Aspect 16:10)
    20.072| Standard timing identification #6
    20.072| code 0x9500 (HActive 1440 Pixels VActive 900 Lines RefreshRate 60Hz Aspect 16:10)
    20.072| Standard timing identification #7
    20.072| code 0xd1c0 (HActive 1920 Pixels VActive 1080 Lines RefreshRate 60Hz Aspect 16:9)
    20.072|
    20.072| monitor descriptor 2 type 0xff
    20.072| Monitor S/N: 1128151602854
    20.072| monitor descriptor 3 type 0xfd
    20.072| Monitor range limits
    20.072| min vfreq 55 max vfreq 76
    20.073| min hfreq 30 max hfreq 83
    20.073| max pixclk 170MHz (0)
    20.073|
    20.073| monitor descriptor 4 type 0xfc
    20.073| Monitor name: PLX2783H
    I forgot to say that I obtain this debug log only with my macmini. On my amigaone x5000 I do not obtain any debug log.
    Brumiga
    [ Edité par Brumiga 29.09.2024 - 18:33 ]
  • »29.09.24 - 14:20
    Posts: 3319 from 2003/3/5
    @Brumiga
    Ignore it.
  • »29.09.24 - 14:33
    bigfoot
    This is indeed from the TinyGL update, from MOSSYS:Devs/Monitors/Radeon. It's harmless and you can ignore it. It'll be removed in the next TinyGL update I release.
  • »30.09.24 - 06:14
    Brumiga
    Thank you bigfoot for your clarification.
    Brumiga
  • »30.09.24 - 12:31
    Falcon_11
    Posts: 35 from 2004/2/7
    Thank you Bigfoot for your hard work. Offcourse also others.
    Falcon_11
    [ Edited by Falcon_11 30.09.2024 - 19:29 ]
    DEAD
    Pegasos-II
    Powerbook G4 A1139, MOS3.19
  • »30.09.24 - 15:27
    anchor
    Posts: 8 from 2014/1/1
    For me FBO is not advertised with SDL2.
    - I updated TinyGL with TinyGL-Update-2024-09-29.lha
    - I calling tglEnableNewExtensions(0) after calling SDL_GL_CreateContext(), and before listing extensions.
    but EXT_framebuffer_object is not advertised.
    could anyone use FBO with SDL2?
  • »20.10.24 - 06:27
    beworld
    Posts: 672 from 2010/2/10
    Have you update to last SDL2 ?
    No need to call tglEnableNewExtensions, SDL2 do it: https://github.com/BeWorld2018/SDL/blob/SDL-2.30.7-release/src/video/morphos/SDL_mosopengl.c#L178
    I think you need to force OpenGL 2.0 detection, i see "OpenGL 2.0 not available".. force that. tinygl send you OpenGL 1.2...
    After i need source to check and test
    My MOS ports
  • »20.10.24 - 07:12
    anchor
    Thanks Beworld, my SDL2 was deifinitely outdated.
    I updated to SDL-2.30.7, but now i'm getting compile error:
  • »20.10.24 - 08:45
    beworld
    ok wiht last version of SDL2, you need to put "-lGL" after -lSDL2
    My MOS ports
  • »20.10.24 - 10:45
    anchor
    Thanks for your response Beworld!
    Actually i had no -lGL in the makefile. If i put it after -lSDL2, the error is the same :/
  • »20.10.24 - 14:53
    beworld
    so... you dont have last TinyGL SDK :-)
    My MOS ports
  • »21.10.24 - 08:47
    anchor
    Beworld: seems yes, but i ran the latest update... how can i check the installed TinyGL SDK version?
  • »21.10.24 - 09:10
    beworld
    Into last archive: https://tinygl.molsen.co.za/TinyGL-Update-2024-09-29.lha
    You need to read "readme".... :-)
    Part SDK:
    delete gg:ppc-morphos/lib/libGL.a
    copy SDK/GG/#? gg: all quiet clone
    My MOS ports
  • »21.10.24 - 10:34
    anchor
    Thanks Beworld!
    Now my test project is compiling.
    The binary format geometry loader has endian problems, it's easy to modify.
    The real problem is the shader compilation:
    Image: tinygl4.png
    Would be good to know is the max uniform count, and other limits.
    Anyway, this TinyGL is promising from now :)
  • »22.10.24 - 06:55
    Tcheko
    Posts: 544 from 2003/2/25
    Keep in mind. R300 is pretty limited to only 64 instructions. Instructions not natively supported are emulated with multiple instructions as well, which doesn't help either. :)
    Multipass is the only way to get around that. If your shader is failing, simplify until it compiles...
  • »22.10.24 - 09:35
