MorphOS on CSPPC wont boot - SOLVED
    JohnFante
    Posts: 162 from 2006/9/4
    Ok.
    I have a A4000D (KS3.1,OS3.9) with a CSPPC and a Cybervision 64 + AdrianeII network card.
    I have 4 partitions on my IDE harddrive. (IDH0,1,2,3). I have copied the content of the latest version over to IDH3). And placed a kick.rom file (made a copy of my kickstart through Amiga Explorer) in IDH3:DEVS/Kick.rom.
    MorphOS wont boot. It boots a little, and then i get a AmigaDOS screen saying "startup failed returncode 10"
    My startup-sequence is:
    ; This is the MorphOS loader startup-sequence. If you set the MorphOS partition as bootable,
    ; this file would cause MorphOS to get loaded on boot automaticly.
    ; By default MorphOS boots without using the ROM contents of your Amiga. If you wish to
    ; make it use the kickstart contents (to be able to use trackdisk.device for example)
    ; please follow those steps:
    ; 1) Check if you have a correct kickstart file:
    ; The Kickstart version required are:
    ; Amiga4000/4000T/3000 - 40.68 or 40.70
    ; Amiga1200 - 40.68
    ; Is is advised that you use the unpatched ROM files
    ; 2) Move or delete fakerom.elf from boot/extmoudles
    ; 3) Change the kickstart variable, remember to tune the file path
    set kickstart "kickstart=IDH3:Devs:Kick.rom"
    ;set kickstart "nokickstart"
    ; Bootdevice can be used to specify the MorphOS partition if you have more than one
    ; bootable partition and the MorphOS one doesn't have the highest boot priority. Remember
    ; to use partition names, not volume names! This option requires the 'bootdevice' keyword
    ; like in the example below:
    ; set bootdevice "bootdevice=DH1"
    ; Leave the var blank if you want to boot from the default boot partition!
    set bootdevice "IDH3"
    ; The resetlevel and delay variables are there for you to tweak if MorphOS startup doesn't
    ; reboot the machine properly after loading MorphOS files.
    ; The possible resetlevel values are:
    ; 0 exec/coldreboot (System Reboot)
    ; 1 MMU switch off + normal reset in chipram (default)
    ; 2 MMU switch off + double reset in chipram
    ; 3 MMU switch off + Cyberstorm HW Reset in chipram
    ; 4 for (;;);..waiting for manual reset by your hands:-)
    ; 5 MMU switch off + normal reset in fastram
    ; 6 MMU switch off + double reset in fastram
    ; 7 MMU switch off + Cyberstorm HW Reset in fastram
    ; NOTE: most common setting for BlizzardPPC is resetlevel 1 and 5 for CyberStormPPC!
    set resetlevel 5
    set delay 1
    ; Load the MorphOS loader!
    cd sys:boot
    startup hal=roms/hal.com1 kernel=roms/kernel.com1 abox=roms/abox2.com1 module=roms/module.com1 resetlevel=$resetlevel ramdebug verbose debug EDebugFlags="NoLogServer NoLogWindow" sumkick disableled delay=$delay extmodules=extmodules/#? $bootdevice $kickstart >NIL:
    Thanks in advance!
    [ Edited by JohnFante on 2006/9/17 12:40 ]
  • »16.09.06 - 12:55
    DJBase
    Posts: 745 from 2003/4/6
    I saw 2 errors in your startup-sequence:
    set kickstart "kickstart=Devs:Kick.rom"
    set bootdevice "bootdevice=IDH3"
    [ Edited by DJBase on 2006/9/16 16:34 ]
  • »16.09.06 - 13:32
    JohnFante
    Thanks!
    That helped a bit. Now it boots for a short while, the screen blinks (I have a monitor that can show both AGA and Hi-res screenmodes), the HD light is turned on for a couple of seconds and then it halts.
    I have nothing enabled in my CSPPC.
    I use normal FFS (default).
  • »16.09.06 - 14:03
    DJBase
    If you remove the >NIL: maybe it will give an output.
  • »16.09.06 - 14:23
    JohnFante
    Now it shows a Dos screen saying MorphOS is starting up.
    After a couple of seconds it is back to the black screen from before.
    At least something is happening.
  • »16.09.06 - 14:33
    DJBase
    But you are aware that after MorphOS reboots the screen will stay black until the bootlogo will be shown? This may can take a while.
  • »16.09.06 - 15:46
    JohnFante
    How much is a while. Are we talking minutes? ;-) I have waited 5 minutes now, and that must be to long.
    I think there is another issue.
    Thanks in advance.
  • »16.09.06 - 22:27
    Slayer
    Posts: 37 from 2003/9/28
    Try using the idehack module instead, this worked for me
  • »17.09.06 - 06:46
    JohnFante
    Thanks that worked!
    Cool! MorphOS kicks ass.
  • »17.09.06 - 06:54
    Amigaz
    Posts: 121 from 2005/6/11
    I'm in the process of building a new A4000 tower with my CSPPC/CVISIONPPC and want to try MOS on it but what is this idehack module mentioned here?
    I guess I will need it too  ;-)
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »28.09.06 - 06:15
    amigafan
    Posts: 1 from 2006/12/2
    Hi
    I`ve got similar problem with my A4000T CSPPC+CVPPC (blank screen after reboot) so would like to know what is this idehack module?
  • »02.12.06 - 10:10
    Amigaz
    amigafan wrote:
    Hi
    Had the same problem
    Please read THIS
    Pegasos II G4 1ghz
    Radeon 8500 128mb
  • »02.12.06 - 12:03
