Ambient version PowerUp
    VooDoo
    Posts: 189 from 2005/8/24
    heya..Today install last Ambient (1.43 12.11.06)version on my Amiga whit MOS powerUp..but is slow :( my old 1.41 is FASTER but dont work whit MUI 4..
    now question...what Ambient work fast and OK on PowerUp? and what is the best settings for Ambient?
    corectly need all info what speed Up my mos :)
    Thanx!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1 :-D
    Warp croatian Amiga portal :
  • »13.11.06 - 18:59
    Framiga
    Posts: 363 from 2003/7/11
    but... don't you said to have Sputnik up&running with Ambient 1.41 and MUI4?
  • »13.11.06 - 19:21
    VooDoo
    yeah..but whit Ambinet 1.41 and MUI 4 I dont have actov icon launchbar...is loading on desktop but dont work..whit last Ambient all i OK...
    That is only reason what I need freesh Ambinet version!
    A1200 sandwich
  • »13.11.06 - 19:41
    Framiga
    ah, ok yes the Ambient 1.41 Panel, doesn't works with Mui4.
    this version works just fine on a csppc (apart YAM 2.5dev, that take 5 seconds to iconify/quit due Mui4)
    http://fabportnawak.Free.fr/ambient/ambient-1.43-20061111.lha
    if only i could get Sputnik working on my system! tried everithing.... nada.
  • »13.11.06 - 19:58
    Posts: 109 from 2006/9/10
    You probably downloaded an Ambient build that has debugging enabled, which slows things down considerably (especially visible with Powerup).
    I think the link that Framiga quoted is an Ambient build without debugging. It should run much faster. Also try to reduce gradients in MUI4 etc. to speed things up.
  • »13.11.06 - 20:08
    Adam_K
    Posts: 34 from 2006/3/31
    On my MorphOS PUP I'm using old but still very good Opus Magellan II + MUI4. And I don't need (slow on clasic Amiga) Ambient at all.
    Sputnik works on my machine also without problems :)
  • »13.11.06 - 22:15
    AmigaMancer
    Posts: 265 from 2005/8/25
    That's right. I can say from my expirience that the debugless version of Ambient 1.43 not only it's not slower than v1.41 but it is actually faster!!
    If you have a lot of partitions, i think it's a good idea to disable volume gauges to get a marginal speed boost.
    That's right. I have made a post about this. I haven't test it yet with MUI4 BETA, though:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4822&forum=9
    [ Edited by AmigaMancer on 2006/11/14 1:57 ]
    Amiga 1200 user.
  • »13.11.06 - 22:46
