Posts: 934 from 2010/10/29
Here is the hplip page for it:
http://hplipopensource.com/hplip-web/models/laserjet/hp_laserjet_cp1025nw.html#note8
and more info
http://www.openprinting.org/printer/HP/HP-LaserJet_Pro_CP1025nw
and the foo2zjs page which lists this printer:
http://foo2zjs.rkkda.com/
and HPs page:
http://h20386.www2.hp.com/CanadaStore/Merch/Product.aspx?id=CE918A&opt=BGJ&sel=PRN
and the zjstream protocol explained:
http://web.archive.org/web/20020830075425/http://ddk.zeno.com/Reference/ZjStream/Default.htm
bascially, these zjstream printers are raster printers like an inkjet.
pages are processed through ghostscript, converted to flat bitmaps and then converted into zjstream format and sent to the printer.
my printer supports both usb and ethernet, but the data must still be packed in zjstream format to be understood by the printer.
my usb port is broken on the printer at this time so I am using ethernet only.
With the foo2zjs driver, you can print to some Minolta/QMS, HP and possibly other ZjStream printers:
Supported Printer B/W Color Driver Notes
Minolta/QMS magicolor 2300 DL Yes Yes foo2zjs Tested by Rick Richardson
Minolta/QMS magicolor 2200 DL Yes Yes foo2zjs Tested by Adam Erickson.
Konica Minolta magicolor 2430 DL Yes Yes foo2zjs Tested by Ren Rebe
Minolta Color PageWorks/Pro L Yes Yes foo2zjs Tested by tekknogenius.
HP LaserJet P2035 Yes No foo2zjs Beta Quality
HP LaserJet Pro P1606dn Yes No foo2zjs Beta Quality
HP LaserJet Pro P1566 Yes No foo2zjs Beta Quality
HP LaserJet Pro P1102 Yes No foo2zjs Tested by tahir hussain. See "HP SMART INSTALL NOTES"
HP LaserJet Pro P1102w Yes No foo2zjs Tested by Rick Richardson
HP LaserJet Pro CP1025nw Yes Yes foo2zjs Tested by Rick Richardson
HP LaserJet 1022 Yes No foo2zjs Up to Fedora Core 5 is tested
HP LaserJet 1022n Yes No foo2zjs untested
HP LaserJet 1022nw Yes No foo2zjs untested
HP LaserJet 1020 Yes No foo2zjs Tested by Rick Richardson
HP LaserJet 1018 Yes No foo2zjs Tested by Rick Richardson
HP LaserJet 1005 Yes No foo2zjs Tested by Brian Batey
HP LaserJet 1000 Yes No foo2zjs Tested by Andrew Schretter
HP LaserJet M1319 MFP Yes No foo2zjs PRINTER ONLY; Alpha Quality
[ Edited by bash64 17.02.2015 - 23:24 ]Powerbook G4 1.67ghz 2GB, ATI 9700M Pro 128mb
Powermac G5 2.3ghz 2GB, ATI 9600 Pro
