Sputnik 2nd beta released
    Amigaz
    Posts: 121 from 2005/6/11
    wali7 wrote:
    in my case Sputnik dramatically speed up after installing apooler -
    just vertical scrolling... network speed is the same, and this won't
    be improwed until marcik implement cache
    have you installed apooler in user-startup? is apooler listed after
    STATUS command?
    Have it in my user-startup but there's nothing with the name "STATUS" in it
    We're running MorphOS PowerUP here ;)
    MorphOS PowerUP powered Amiga 4000
    Pegasos II G4 1ghz
    Radeon 8500 128mb
    Soundblaster Live 5.1 Digital
    Realtek 2139B 100mbit
  • »12.03.07 - 15:43
    Golem
    Posts: 766 from 2003/2/28
    That's nice, now try running the command Status in a shell window.
  • »12.03.07 - 15:47
    jcmarcos
    Posts: 1178 from 2003/3/13
    Golem wrote:
    Can I donwload these fonts from elsewhere, instead of using the script at home?
    Yes, just read the script, it's quite simple really.
    Done. It's strange that there's not an archive with just the TTF files, but a series of Windows executables. Thankfully, 7Zip was able to extract them.
    Aside from the font files, Sputnik includes a certain "ttengine2.database" text file, which is ignored by this script. Will put it in "env-archive", as its source suggests.
  • »12.03.07 - 15:47
    Posts: 2053 from 2003/6/4
    A great step to the right direction.
    Speed is still an issue, as are some layout issues (e.g. www.n-tv.de has still severe probs). Also forms do not work fully (I cannot log in e.g. aw.net (but that might be with intention ;-) )).
    But a big step into the right direction anyway.
    Keep up the good work.
  • »12.03.07 - 16:01
  • Targhan
    Posts: 2833 from 2003/2/8
    @Krashan
    Yes, OpenURL adds the port number to the arexx port. Shouldn't have to type in the arexx port for Sputnik at all, since OpenURL has a dropdown box with a list of Arexx ports ;-)
    :idea:Targhan
  • »12.03.07 - 16:29
    Posts: 1068 from 2003/3/24
    Thanks for this great release but i have still some chrashes when saving the Prefs.
  • »12.03.07 - 17:17
    wali7
    Posts: 24 from 2007/3/10
    Status is a shell command - it lists all active processes, apooler
    should be listed too, if not - apoller isn't running.
    After all - I am user of PegII with G4 1 GHz... on my machine
    scrolling is smooth, maybe elder PPCs are too slow?
    [ Edited by wali7 on 2007/3/12 19:50 ]
  • »12.03.07 - 18:48
    realstar
    Posts: 298 from 2003/2/24
    apooler made a big difference on my system PegII G4, especially for
    scrolling. The browser is getting a lot better but there are still a
    few issues, mainly to do with refreshing oddly. Also the text entry
    area is messed up on mine, the letters appear way below the cursor
    while typing.
  • »13.03.07 - 00:53
    wali7
    Some problems with text area are connected with default settings of
    MUI String gadget. To solve it - open MUI preferences for Sputnik,
    click on "String" and change color of "container" and "...activated" -
    choose any color (from pens, or color wheel) instead of "Same as
    parent object".
  • »13.03.07 - 07:19
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    @Marcik
    new version is very slow :-(
    old version beta 1 is faster
    test www.gazeta.pl
    Sputnik (beta 1)
    _
  • »13.03.07 - 09:37
    Kamul
    Posts: 121 from 2004/6/9
    On my machine (Peg II G3) Sputnik is a little slower than f.ex. AWeb (I don't mean the lack of cache related slowness), but quite usable anyway. It is stable enough and show sufficient number of sites correctly to use it in place of AWeb. From time the second version of Sputnik appeared, AWeb practically is a history for me. :)
    I don't know how fast Sputnik would be without APoller - I use this program much time before Sputnik was public available.
  • »13.03.07 - 19:23
    GK_LKA
    Posts: 481 from 2004/3/28
    I think the main problem is not with the speed, but with the flickering, bad page rendering, and not working pages (especially GMail, GoogleMaps, etc.)...
    I know, it is a beta, and these features and weaknesses are acceptable at this stage. :) So it could be sometime a great browser for MorphOS, but it needs some more work :)
    When could we expect the next beta? ;)
    [ GK / LKA Team ]
  • »13.03.07 - 21:16
    dIGIMAN
    Posts: 273 from 2005/11/7
    Just wanted to notice that i also had a huge speedup with apooler from unusable to quite ok.
    I use a G4 Peg2.
    Everybody should atleast give it a try
  • »13.03.07 - 22:10
    Brumiga
    Posts: 241 from 2004/4/3
    Hello,
    I tested spulnik with the two versions of apooler on my provider web page, www.orange.fr . In the two cases in statline I saw the cpu staying between 95 % and 100 % during 15 minutes. The memory decreased during these 15 minutes when the page is loaded from 409 mo to 259 mo with last version of apooler and from 409 mo to 298 mo with the first version of apooler.
    With the first release of sputnik and the first version of apooler I had no problems of this kind on my provider web page.
    Brumiga
    [ Edited by Brumiga on 2007/3/14 13:20 ]
  • »14.03.07 - 12:17
  • DDJ
    DDJ
    Posts: 99 from 2003/2/24
    Hi all, second try and now with some updates and tips
    from here, this is the situation;
    1 - Updated my Ambient from 26/02/07 to 11/03/07
    2 - Installed apooler 1.0a
    Results
    The slow scrolling gone;-), the loading page speed get
    a little beter, down from 54s load to a 46s load in
    this site www.terra.com.br, so I can use sputnik now
    and wait for the next beta.
    Obs: A allmoust freezy situation in MOS can be done
    opening sputnik prefs and then hit the cancel button
    without changing anything.
    Again thanks Marcik.
    Peg2 G4 1Ghz rev. 1.2 - CPU rev 1.2 - Built on 20050808
    OF-version 1.2 (20050808153840)
    Radeon 9250 (9200Pro) 256MB/128bits AGP - OEM PCVIEW (ProLink)
    RAM 1GB - 2x512MB DDR333 CL2 - Kingston HyperX
    40GB ATA100 - Brand ?
  • »15.03.07 - 04:37
    wali7
    I had very high CPU (1 GHz 7447) load (higher than 90%) for several minutes - before installing apooler. The other symptoms were very slow and annoying webpage scrolling and high Sputnik closing (above 10 s). After installing apooler I observed the highest CPU load not higher than 60% for 5 s. Slow scrolling and closing Sputnik also have done.
    I use apooler version 1.0a. (It is easy to check is apooler running, it should be listed by Status command in shell)
  • »15.03.07 - 08:04
    samo79
    Posts: 87 from 2003/7/26
    Hi Marcik,
    I have a simple question, now that we have the Beta 2 up and running, what do you think to add for the Beta 3 and what is the timeline of it ? :-)
    Bye
    BACK FOR THE FUTURE
    http://www.betatesting.it/backforthefuture
  • »09.04.07 - 20:52
    matt3
    Posts: 659 from 2004/2/10
    I have an issue with Sputnik...
    I have a huge area between the address bar and the actual website rendering. How do I remove it?
    Regards,
    Matt
  • »11.04.07 - 01:08
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    Matt
    I think this one might be covered earlier in the thread. Just open the Prefs window and save preferences maybe?
  • »11.04.07 - 06:47
    matt3
    Thanks JKD!
    Worked perfect.
    Best regards,
    Matt
  • »11.04.07 - 11:27
  • DDJ
    DDJ
    Marcik, and anyone else ho can help me with this doubt, please :-P, I still dont have Raggae installed in my system, so what will be the goods I can get with Sputnik+Raggae combo, any performance gains? what kind of data will be handled with this new "datatype system" when I start to Browse internet with Spunik?
    [ Edited by DDJ on 2007/4/13 17:01 ]
  • »13.04.07 - 20:59
    Posts: 186 from 2003/10/23
    if u don't have raggae installed u cannot run sputnik.
    Sputnik uses raggae a lot for http stream and other task, so u must install it (the installer of sputnik install raggae automagically for u ^_^)
    I'm nerdy in the extreme
    And whiter than sour cream
    White&Nerdy 2006 Al Yankovic
  • »13.04.07 - 23:13
  • DDJ
    DDJ
    Then I whitout knowing :-P, already have Raggae installed.
    Thanks.
  • »13.04.07 - 23:19
    Framiga
    Posts: 363 from 2003/7/11
    Sputnik have an installer? which installs what? :-?
  • »13.04.07 - 23:34
    the first beta have a script to install the mui,font and reggae necessary to work (if i remember correctly)
  • »13.04.07 - 23:41
