ezTCP - try #2
    Posts: 408 from 2004/7/15
    Compiled next changes yesterday. Packets are sent to the network correctly. Nothing is received, but i guess the problem source is simple.
    There will be no support script, everything will be written in C code.
    iPod, iBook, iMac,... iRobot?
  • »18.11.05 - 06:55
    I am glad to tell that i am at last moved away from the deadstop. It was tricky but i at last dealed with interface configuration and routing. Now dhclient sends out packets to the network but they are broken since there are currently no means to obtain hadrware address of an interface. This is being implemented now. I hope soon i'll get everything working.
    I am sorry again for long delays. The kernel is really horribly outdated, a plenty of time is needed in order to bring it up.
  • »25.11.05 - 06:11
    I've at last finished writing, in the evening i'll try to compile the whole thing :)
    The kernel is heavily fixed and updated. It supports a number of new IOCTLs and also i implemented an interface to statistics structures. "ifconfig" utility will be also upgraded to accomodate all changes. Probably i'll even build new normal "netstat" utility since everything is ready for it.
    DHCP should start working at last after these changes. AF_LINK is fully supported now.
    Changelog grows at a frightening speed...
  • »25.11.05 - 10:31
    SoundSquare
    Posts: 1213 from 2004/12/1
    how can you be sorry ? you're going so fast and did such an amazing job ! congrats !
  • »25.11.05 - 13:35
    Posts: 1068 from 2003/3/24
    I can only second that what Soundsquare is writing!
    It's amazing to read and see the progress you make with the Port.
  • »25.11.05 - 16:22
    Posts: 1915 from 2003/10/19
    As I've said before, WELL DONE! I cant wait to see the results! Keep it up, your just fantastic!
  • »25.11.05 - 16:41
    And here are my words tured into working code:
    https://sourceforge.net/project/screenshots.php?group_id=133480&ssid=22376
    As you can see here, DHCP client at last obtained an IP from the server. All i need now is to replace that "Running script" with C function configuring the interface (there is no script and will never be, it's just a stub function which just prints parameters with which the script would be called).
    I really hope i'll produce a new beta soon.
  • »28.11.05 - 06:46
    YES! When DHCP is in a beta that I can get I will use it at last! I cant wait. Thanks again Sonic, well done!
  • »28.11.05 - 18:04
    zephar123
    Posts: 139 from 2004/3/8
    its coming along great sonic thanx for all your hard work so far =).
  • »01.12.05 - 03:30
    Heh... Decided to make next report just so as not to be quiet...
    1. Updated kernel and environment components are built. Not everything works as expected, errors are non-fatal (netstat shows nothing, ifconfig doesn't show MAC addresses). I guess something is wrong in my kvm_read() function. "ifconfig" tool is now re-adopted from NetBSD because FreeBSD implementation is poor. NetBSD doesn't use that KVM crap and therefore doesn't introduce additional problems. Probably all future development will be based on NetBSD and not FreeBSD.
    2. DHCP client itself is being finished, additional interface configuration routines are being written.
    I really hope everything will settle up next week. This is a very large update, that's why so much work is required.
    [ Edited by Sonic on 2005/12/1 17:49 ]
  • »01.12.05 - 06:21
    MorphDelf
    Posts: 274 from 2004/2/20
    You do a wonderfull job Sonic. I will use your tcp/ip stack forever, just to show my support. Thanks for beeing so supportive! And all of you reports on how your progress is going on,..
    Thanks again!
    Regards,
    Michal
  • »01.12.05 - 21:18
    killlbilll
    Posts: 95 from 2004/5/19
    Wow. Forever? Will you marry it? ;)
    [ pegasos ii / g4 | morphos1.4.4 ]
  • »01.12.05 - 21:54
    MorphDelf
    Yes ;p
  • »02.12.05 - 11:56
    Well, well, here are the latest news:
    1. ifconfig utility fixed - works.
    2. netstat utility actually works but requires to implement some additional functions. So - left out for now. However it perfectly serves my debugging needs - dumping routing table.
    3. DHCP client modifications are being finished.
    So - soon v0.14 will be delivered. Thanks to all for your support.
  • »02.12.05 - 12:17
    Looking forward to it, will it have a GUI and be easy to install and setup?
  • »02.12.05 - 12:50
    http://prdownloads.sourceforge.net/unmorphos/ezTCP0.14.lha?download
    Sorry, no new GUI parts yet. I will start MiamiPanel support as soon as DHCP support is 100% finished and tested.
    I modified the configuration editor a bit, it looks much better now. Probably after some time you'll see first screenshots.
  • »05.12.05 - 06:37
    Posts: 889 from 2004/1/24
    Or download it here :-) :
    https://morph.zone/modules/mydownloads/singlefile.php?lid=334
  • »05.12.05 - 08:22
    Senex
    Posts: 498 from 2003/2/17
    By the way: Don't know if someone did mention this before already, but as someone pointed out at amiga-news.de today, there is already a commercial product called ezTCP, too.
    http://www.eztcp.com/
  • »06.12.05 - 16:10
  • Targhan
    Posts: 2833 from 2003/2/8
    Sounds like it's time for a poll with a new name for what was once called ezTCP... Ideas?
    :idea:Targhan
  • »06.12.05 - 18:41
    SkyRider
    Posts: 2 from 2004/9/16
    Hi, I can't compile the Ambient Source with the MOS SDK.
    The Error Messages are "permission denied" or "write protected." With Miami it works fine.
    Greets
    SkyRider
  • »06.12.05 - 22:15
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 24.09.2011 - 04:12 ]
    Pegasos2 G3, 512 megs RAM
  • »07.12.05 - 02:14
    Velcro_SP
    Or Sonic TCP?
  • »07.12.05 - 10:16
    EasyTCP
    MiniTCP
    MorphTCP
    SonicTCP
    BlueTCP
    MOSConnect
    MorphConnect
    MorphNet
    etc. etc. :-)
  • »07.12.05 - 10:49
    Huh... Could you explain the situation a bit more detailed?
    What does actually happen? When? Under what conditions?
  • »07.12.05 - 11:07
    March
    Posts: 91 from 2003/7/30
    This must be a problem with ixemul apps and usergroup.lib from
    ezTCP. There is also problem with my OpenSSH port - it hangs,
    when launched with usergroup.library from ezTCP. Also cvs tool was
    reported not to work correctly. When I replaced the lib with
    usergroup.library from AmiTCP all ixemul apps works
    fine.
    Marek Szyprowski ...... happy MorphOS, AmigaOS and Debian/Linux user ........
  • »07.12.05 - 12:44
