ScoutNG bounty proposal
    NewSense
    Posts: 1596 from 2012/11/9
    If I run PageStream v4 then it is not shown in the Scout v1.2 - *Application* - option, though the PageStream4 Screen Ttitle is shown in the *Windows* option. However, in the *Screens* option the main window and any sub-windows like the toolbar are shown within the 'Screen' field as '0x2900f624' - but unnamed [blank-field title]. So, is this to be expected for a non-MUI screen, as PageStream 4 as it is not a MUI application, as it runs under 68k Trance?
    Scout v1.2 runs very stably for me on my MacMini, so many thanks for completing this program. 8-)
    MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
  • »01.01.20 - 23:09
    Posts: 3291 from 2003/3/5
    You won’t see Pagestream cause it isn’t a MUI application. Scout will only show MUI apps with at least one opened window.
  • »02.01.20 - 05:35
    Posts: 12529 from 2003/5/22
    > [...] as it runs under 68k Trance?
    This shouldn't matter.
  • »02.01.20 - 07:56
    Scout 1.3 is now on morphos-storage. I've fixed a couple of UI quirks and re-worked the MUI applications list scanner so that it now shows all running apps.
  • »03.01.20 - 04:42
    Templario
    Posts: 556 from 2012/4/28
    Thank you for the update!
  • »03.01.20 - 10:02
    Scout 1.5 is now on morphos-storage. Fixes a couple of quirks in Devices.
  • »15.01.20 - 00:28
    Thanks for all the updates on this project.
  • »15.01.20 - 23:41
