                Posts: 459 from 2003/8/30
				I don't want to be a buzzkill, but racing off to have  files "automated" may not always be a good idea.
case in point:
I recently downloaded 3 mui files from aminet. I installed them (the ones' labled for MOS) on my peg. all seemed fine until I tried starting up April (1.138).
April opened but I was unable to right-click the prefs as is normal. hmmmm. I mean, not being able to access the dates and the prefs makes it useless. except as a pretty pic on my wb.
Because I
knew which files i had recently included in my system, I proceded to - one by one - rename and reboot, seeing which mui file was the one messing with April.
turns out TextEditor.mcc ver 15.16
             TextEditor.mcp ver 15.11
was the issue.
I returned using TextEditor.mcc 15.11
and it works just fine.
I can't say what the problem is, but that is for others (who understand programming) to discover.
Anyway, let's not be so quick to want everything automatic. it's too early for that. we still need to make baby steps with this work.
"if you ever slam anyone, for anything, somehow you always end up eating shoe"   Targhan
