Moderator
Posts: 2581 from 2003/2/24
Well well ....
Ports or not ports that is NO !! question
GDB, alias the GNU-debugger is out there, so it would be a port, but the one that I want would have a MUI-GUI.
The rapid-dev thing would need to be tailor-made for MUI, but that doesn't mean that one couldn't get ideas and some sources from similar projects on other platforms.
Databases and finance-apps do exist on Linux, and adopting them to MUI/locale/ARexx ought to be enough.
There are also free spellchecker, one would just need wrap them into a library, and define a suitable API.
Bout the bounties themself:
Those should be free, and available with no strings attached, but I see no reason why the coder should be forced to go open-soure, or be forbidden to sell newer version.
But if a program is closed-source, it should go through intensive testing before the bounty is rewarded.
