Posts: 1476 from 2012/11/10
I thought I had an issue with ebay the other day when my PURCHASE HISTORY page loaded - but was BLANK, that means the ebay page itself loads, so that the menu loads on the left, and the header and footer information are shown but NO PURCHASES - NO LIST of items bought is shown at all.
I flushed the cookies for ebay (all of them) and still have the same problem. I contacted ebay who said all was OK at their end, and now that I have switched on my Windows system and run Firefox the Purchase History page loads OK.
So, I can only think that ebay have recently changed some part of their Javascript for that page which is not supported in OWB.
I was using OWB v1.24, but have also tried OWB v1.22 and get the same result with both versions of OWB.
Unless someone else has another solution to fix this issue?
EDIT: I have since learned that ebay have definitely changed the format of the PURCHASE HISTORY page, and added a couple of options onto the page, and I feel sure this is what OWB cannot handle, so until it gets fixed the ebay Purchase History page will remain 'broken' as far as OWB is concerned
EDIT2: I have returned to the ebay Purchase History page, and now find that it is working as it should again with OWB, so what the problem was with it I have absolutely no idea.
So that's one problem solved, but the issue with the Gumtree website still continues and I cannot update any of my adverts with OWB, and have to rely on dropping back to Windows or Mac OSX and use one of the browsers on those platforms to do any editing I need for adverts I have on that website.
I know it's not a major problem, but OWB still needs fixing for that website.
[ Edited by NewSense 31.07.2014 - 23:53 ]MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.18+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
