Posts: 146 from 2013/2/18
STATUS/ SOLUTION UPDATEHow to get Youtube to run Smoothly in OWB (for newbees)
1. Go to: http://www.youtube.com/html5 (to activate html5)
2. Download the plugin SWFDEC at this address: http://fabportnawak.free.fr/owb/plugins/swfdec_plugin-1.2.lha
- .lha format needs to be unzipped/uncompressed (double click the file)
- The destination you must use for the unzipped content is: applications:OWB:Plugins (Application drawer and then OWB drawer and the Plugin Drawer)
3. Download the latest OWB scripts at this address: http://fabportnawak.free.fr/owb/scripts/
- Place the scripts in the drawer Applications:OWB:Scripts
- Overwrite existing files if the same already exist
4. Start OWB and go to the menu "Windows" and choose the dropdown "URL settings"
- add www.youtube.com, select to spoose it as either Safari or iPad (it will give different looks on youtube layout)
5. Go to menu "Windows" and choose the dropdown "Scripts" and disable Youtube "EZ download" script if you like to get rid of the partly annoying overlay for downloading videos.
Enjoy smooth streaming videos-If you've never failed, you've never tried -
